Hey MTC,
I'm planning to start towing with my 22 EB 4k Maverick. I'll likely be running fairly close to the max loads and wanted to add some parts to make it easier to drive and safer for me & the truck. I've already replaced the transmission, PTU & RDU Fluids (highly recommend! write up here) and I'm looking for ways to tweak the suspension to handle the tongue weight and help with driving/handling. I also ordered this nifty Weight Safe hitch that measures the weight in real time so I'll now if/when I'm overloaded before taking off.
Below are the 3 main options I found without replacing/modifying the entire suspension. I don't want to get into weight distribution hitches as I'm not convinced they're a good idea on a unibody truck and would rather beef of the mav where possible.
Please let me know your thoughts on what I should add/modify!
Air Lift 1000- ‎60859 (Amazon): Cheapest option
Air bag "springs" that inflate inside the existing spring suspension. This seems like the cheapest & most adjustable way to level the truck under load and better distribute the weight. Other installations make it seem a bit tricky to get the bags into the springs, but definitely possible without removing any parts! I like that these are adjustable based on the load that's on the truck (add/remove psi), but I'm concerned on how these will impact normal driving, if there is a chance it voids the warranty, and/or if it causes increased wear since the truck is loaded differently than designed (some lift kits have this problem, especially on ball joints).
Sport Timbren SES Suspension Enhancement System (link): Easiest option
A rubber cylinder that supports the truck under load. I like that these are easy to install (direct bolt on), they're not engaged at all under normal driving (same drive feel), and prevents damage if you hit a pothole or bottom out on a bump. Timbren claims that they provide variable support where resistance increases with higher loads, but I have doubts that it's that much of a change. This option seems like the easiest to install, definitely helps, but is limited in its ability to shift weight to the front & level the vehicle under load.
Steeda AWD Rear Anti-Sway Bar (link): Helps with driving, but not with towing
This is a part that I've been looking at for a while. It helps the side-to-side sway and keeps the truck level when going around turns. From what I've read, this doesn't really help with towing as the trailer and truck sway aren't really connected all that much. The trailer is going to sway regardless of what the truck is doing, and the sway control tech in the mav will help here (plus properly sizing/loading the trailer). Overall, I've heard that these are great when driving normally, and want to make sure I won't regret having them when I'm towing.
My Plan:
I'm currently planning on installing all 3 (crazy, I know). I like that the air lift provides adjustable support based on the load, and that timbren offers a fixed "bottom end" support when heavily loaded or hitting a bump. Plus, I hear great things about rear anti-sway bars on normal ride and drive feel.
My concern is that these systems will not work well with each other and/or the sway bar will make towing more challenging. Let me know if it's crazy to do both air lift and timbren, and if the sway bar is worth it if I'll be towing.
Thanks!
My Plan:
Thanks!
