- First Name
- Guy
- Aug 27, 2024
- Memphis, TN
- 25 Lariat AWD Hybrid 4K towing, '24 ioniq 6 limited AWD, '91 BRG Miata 5spd
- Engine
- 2.5L Hybrid
Just an fyi
I just installed a dash cam and a Hyundai mirror with home link. Both devices require a constant 12v and a switched-when-on 12v. The constant on puts the camera into parking lot monitor mode as well as powers the homelink. The switched 12 v enables cam recording and powers up the mirror auto dim and compass.
I didn’t want to cut Into any existing wiring nor am I comfortable putting an additional load on any circuits not designed for them. I like to use spare lines… I wound up use 2 fuse taps. On the 25s the fuse box is under the glove box. There are a number of spare fuses. Fuse 3 is switched and fuse 20 is hot all the time. Easy to tap.
there are two unpainted 10mm nuts on a stud nearby so easy to tie in the ground wire too.
https://www.amazon.com/Cooclensportey-Pack-Types-Upgraded-Circuit/dp/B0CS69VMF8/ref=sr_1_3?crid=18ND3TRGWM675&dib=eyJ2IjoiMSJ9.eCuO71mF_l5-umfj50hX0GxuG7nzEV5GgTBpOMCJJ9yd8k9UEVpzNPDAl5ChsTwnMp8g7VTDPqcxSsDqYeGB_K38_kZ_XOG5Qw2AIjuTmMw---IVIWnO-NKnhy8YXLcQSzHsUZRIUR66dNVItFGoiAzSN7FUaEtcUHQ6M47TroKe40iNYu7PTh1jnZO-qJDtj5WkIcRC5OA_O75X8wHsRJcqUZNVBbYydml-twwPqx0.vl4bkh1gyatPDCYrwWYXW4EMZomIwmp232VO6oKSwYY&dib_tag=se&keywords=Fuse+tap&qid=1743341048&sprefix=fuse+tap,aps,169&sr=8-3
