2025 Keypads battery or wired?
Cristiansilva3312
Cristian
MD
'23 Ford Maverick XLT Hybrid
This one?
HRG
that's the one! thanks. now I can at least give them the part number. where is that though? I can't seem to find it on the ford parts site using that part nunber
Hot Runr Guy
West Chicago, IL
Cristiansilva3312
Cristian
MD
I found the part # on page 13 of 44 of the programming instructions.
https://www.fordservicecontent.com/...G544_AC_On_Line_Instruction_Sheet_11_2024.pdf
HRG
I just read the document you posted. thank you btw that's very helpful. In the instructions I have for keypad installation it says to program using fdrs.
In the pdf you sent, it says to the only way to reprogram via fdrs is with the master key located on the plastic keycard right? the keycard was lost so i assume that means they need to order and program a new keypad.
Hot Runr Guy
West Chicago, IL
My Kung-fu Google search led me to this thread, about retrieving a "flash code" that the dealer can then use to retrieve the master code.
https://www.fordtransitusaforum.com/threads/missing-keyless-entry-master-code.91431/
No idea if it works, but might be worth a try before ordering a new keypad,
Side note, I like the new style keypad they've developed, looks better than the previous stick-on version.
HRG
Cristiansilva3312
Cristian
MD
HRG
you are a legend. I'll have them look at this when I go later this week. big thanks!
