2023 Lariat with black appearance package - driver tail light replacement
gp1200x
Paul
NY
My tail light broke - backup up into a plastic garbage can and of course it hit the light instead of the bumper.
Since I have the Lariat with the BAP (rear blacked out tailight) and led lighting what are my options?
Is a Tremor tail light with LED the same tail light as mine?? I cannot find a part number anywhere for my tailight so I might have to pull it to see what it is.
Another option might be to get a standard Lariat tailight without the BAP and use the ZEP as in the you tube video to remove the chrome to try and get the same look as the pass tail light. I will then probably have to use the ZEP on that too to get them to match.
Any ideas? The Tremor looks like it might be the same light if it has LEDs. The Ford sites do not appear to list the part numbers for these tail lights from what I can find.
gp1200x
Paul
NY
Update...part number is PZ6J-13405AC sticker on light says Lamp Assembly - Tremor LH and it has bulbs and not LEDs in it even though it is a Lariat BAP light.
VicRattlehead
Mokena
Couple ford cars and a truck
my understanding, all the bap taillights are the same. lariat xlt and tremor
gp1200x
Paul
NY
I think that is true and the true Ford part number appears to be PZ6Z-13405B which is not the actual part number listed on it - may have been changed over time. These lights have 3 bulbs and a fourth socket which may or may not be an led bulb for the side of the truck...did not pull it out yet...versus the base units that just have 3 bulbs, no center backout of the chrome and no fourth bulb socket for the side.
2023Area51
Midwest
2023 Maverick XLT Hybrid
You can do the ZEP method on a regular Maverick tail light. If you do this, you will have to ZEP your BAP'ed headlight as they will look different. Despite it being a Black Appearance Package, there is a bit of chrome in the BAP tail light.
gp1200x
Paul
NY
I watched that video...pretty impressive and I was going to do that but you are right...it removes the chrome from the backup light socket so you would have to do both and loose some backup lighting coverage. However I had unused Ford points and used them and bought a new lense for $101 out of my pocket but used up all my points too. The points have a time limit if I recall too.
Jetlat7878$
Woodstock GA
2024 Maverick Lariat Blackout
If anyone has a 2024 Maverick Lariat, the Lasfit T-3 series bulbs will not work, Lasfit now states that fact on their web site and in fact the bundle kit now omits the red T-3 bulbs for the Lariat. I tried those bulbs and they hyper flash.
The solution that works for me is to purchase from Headlight Revolution the following:
Tail/Brake/Signal
Four GTR.LED 285 Lighting Armor Series 4257 LED Bulb Red
Four Morimoto Resistors 40Watt 7.5ohm
Front Turn Signals
Two GTR. LED 284 Lighting Armor Series 4257 Amber
One (2 Pack) Ultra GTR Pro Resistors 6ohm
This option works with absolutely no problems with hyper flashing . Not difficult to install by any DIY type or have a shop install them for you.
Also Digital Dynamics has LEDs on their web site that are designed for the Lariat but I haven't tried them.
