- First Name
- T.
- Jan 15, 2026
- Houston, Tx
- 2026 Maverick Tremor
- Engine
- 2.0L EcoBoost
Response: Not without dismantling the entire front end again.
However, the tow hooks are about 11/16" diameter with a large nut on the back end. After removing the tow hooks I cut them off using a plasma cutter and tweaked the angle to follow the side of the lower plates of the brush guard. Then tack welded them, took the entire assembly back off and layed in 3 passes of good weld using my old Lincoln arc welder. I had considered adding aftermarket tow hooks to the side plates of the brush guard, but that is a lot of leverage to work against the substructure of the front of the vehicle. That is why I've decided to build a winch incorporated into a removable hitch that will allow me to still tow a trailer but have a winch that is secure and also by using the quick connect from commercial jumper cables I can unplug the winch if I need to remove it or Jump off my tractor or anything else. The aftermarket tow hooks will be on the sides of the main tow hitch bar just under the winch plate. Good luck, those factory tremor tow hooks retail for about $300.00ea
