smell when engine gets warm
OleFordGuy
Just a thought, if you have the smell, are you using cheap gas? Cheap gas and catalytic converter issues can cause the sulfur smell. As a test... run truck to almost empty - refill with a tier 1 gasoline brand for a couple tanks - evaluate if the tier 1 gas made any difference. If no difference at least that has ruled out gas as a possible reason. My next thought would point to catalytic converter but i have no idea on the best way to clean its internals. Also might be some sensor for fuel/air ratio or oxygen. Just thoughts running thru my head. Good Luck
OPMav
I'm in Canada and I always fill up at a top brand with high grade gas. We don't really have the tier system to the extent the U.S. does as far as I'm aware. I doubt this is a gasoline issue in my case but thanks for pointing out the possibility.
Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
Don’t think it’s a gas issue. I think it’s a crappy catalytic converter as in cheap. Being that this truck is so cheaply put together to save money who’s to say they used and low budget cat.
The smell I get isn’t rotten eggs though so I’m ruling out the cat. Also no codes pop up as anything to do with the fuel or air.
Maybe it’s the smell of burning ptu/rdu/trans fluid or something in the powertrain. I don’t know just spitballin here. Like one previous poster said it smells of burning matches or something to that effect.
I’m going to drive like I usually do and maybe this burns off. I do only have 1500 miles on her right now.
OPMav
Similar type of smell here. I'm at 15,000km and it's only getting worse unfortunately. I had coolant and transmission checked twice. First time they found a transmission leak but it was minor. Changing the seals didn't help the smell either. At this point all I can suspect is either something is getting far hotter than it should (cat) and/or something is leaking. Looking forward to when Ford acknowledges this is an issue.
OleFordGuy
14mikey14
Marshall, MI
2024 Ford Maverick XLT HPR
I have less than 700 miles on mine and it has happened a few times for me. Smells more like a plastic-ish coolant smell. Only lasts a little bit and then goes away. 2024 XLT Ecoboost.
topgun/goose
earth
metro
Sulfur comes from exhaust and should not be getting into cabin. The Explorers had some cabin vent problems resulting in a TSB for odor problems. Hope we don’t end up having those issues but sounds like we are.
