Removing the front half of center console to gain space?
caring1
Jeremy
Iowa
Lexus, Tesla, Ford
I don’t know how this can be accomplished as there’s a ton and I mean a ton of wiring and wiring harnesses that run through that middle section and in lux package the higher voltage wires to the standard outlet behind the center console.
electruc
F150
Maybe it's just me but, the reason for wanting to do this makes ZERO sense. You have a whole bed, just buy a tonneau cover. But by all means if this space is that important then the Maverick is likely not a good choice. By the way an actual laptop will fit in the side of the door on the Maverick.
Glad you enjoyed the helpful responses, but you sort of ask for it. LOL :)
Why not ignore the question if it makes ZERO sense to you? Are there not different usage patterns for different owners?
I thought I asked a fairly simple question, looking to explore the possibility of removal before purchasing the truck. The bed could be used for other things, and it is more trouble to access things under a tonneau cover for short commuting trips. The center console is mostly wasted space for me, as I don't want to use the bin or cubby to store things longer term between trips.
OTACORB
DAB
Central, Louisiana
Because when you post questions in forums you will get various answers. I understand you don’t like the answer, but in my opinion what you asked makes zero sense.
If that space is important look elsewhere they Mav is not the one.
