- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
This is a quick primer for DIY types who want to flush or bleed their own brakes and have questions about what fluid to use. The easy answer is the shut up and eat your peas response to use what Ford recommends. The longer more important question is why and the next question after that is if so what alternatives meet the why criteria.
First off Ford recommends Dot 4 LV fluid for the Maverick so what is the difference between regular Dot 4 and Dot 4 LV? The viscosity of course since LV stands for low viscosity.
Can you get away with using regular Dot 4 fluid? Probably, you may not run into any issues with regular braking but the LV portion plays a big role in ABS / ESC systems. LV fluids allow the ABS and traction control systems for example to respond much faster and if you have one with an electronic brake booster response difference will probably be much more noticeable especially when using ACC.
So what if I don't want to use Ford Motorcraft fluid are there alternatives? Yes there are as long as they are at least iso 4925 class 6 rated they will meet the viscosity requirements.
https://fcsdchemicalsandlubricants.com/products/brakes/productdetails?id=86
