Line output converter question
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
I'm wondering if anyone uses a more expensive line output converter. I've read the cheaper ones (like i have) will send a distorted signal to the amps. My system sounds great, but, you always wonder "will it be better, cleaner sound quality" if I did this or that. I'm looking at Audio Control and Wavetech converters.
SeanTheLeprechaun
Sean
Huntington Beach, Ca
2024 Lariat EB FX4
Hi BeardedMarine. Which converter are you currently using?
This is my first post to this forum. I am upgrading my front speakers (Focal 165) and installing an 8" Kicker L5 sub with a JBL GTX500 Mono amplifier. I am pulling the sub signal directly from the existing 6x9 factory sub (b&o), however I need a line converter. I will be monitoring this thread as I have read that there have been mixed reviews on some of the more 'basic' converters.
zach57x
FL
2022 Maverick XLT
Use Forscan to change the EQ to flat. Also instead of using a LOC try to use a DSP for the best possible quality
BeardedMarine
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
I'm using some cheap knock off loc, I'd have to go look to see the brand. I'm really leaning towards the Audio Control LC7i. I was thinking to myself, I've put all this money in my system and I'm using a crappy loc.
Edit: I just remembered the loc I used was a Axxess.
BeardedMarine
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
Yeah I've already set my eq to flat and I really know nada about a dsp. If i did learn about a dsp I'd jack with the eq constanty. I'm the type that can't leave well enough alone.
