- First Name
- JC
- Apr 3, 2022
- Southwest Florida
- 2022 Ford Maverick
- Engine
- 2.0L EcoBoost
I have never used that so I can't say. In cases where I have seen anodized pit or corrode two things have been present low PH or Electrolysis. I will look for some Akzoand give that a try. Thank you!Yes anodizing is used in aviation for a reason. I went with the black anodize and it appears to be coated nicely. It is a very corrosion resistant coating. I work in aviation MTX. I still see a lot of anodize stuff get corrosion on it. Especially fluid fittings. Yes for the most part anodizing does help the aluminum from corrosion. What I would be concerned about is water settling in spots on the bottom of the can in the corners since oil floats on water, and slowly corroding the inside. When you open the drain, it's not all going to come out. Some will be left in the corners. In my 28 years of working with aluminum parts I have seen a lot of corroded stuff. This always puts me into a proactive state of mind.
The primer I use is Akzo Noble 10P42NF 2 part fluid resistant epoxy. It is a 1-1 mix ratio. This stuff is impervious to heat and cold extremes. It does not peel or chip off once cured properly. Submerging it in MEK for weeks on end will not remove it. Chemical paint stripper will not remove it either. The only way to remove it is to sand it off or sand blast it off. I have actually used this primer inside thermostat housings on aluminum intake manifolds inside the water passages, and with it heat soaked with with antifreeze continuously soaking it, and it does not come loose.
This is some of the toughest primer I have ever used. If your interested in this, you can get a 2 part kit from Graco Aerospace. I even coated the parts of a friends engine dyno pump that are in water. 4 years later he pulled the pump apart to inspect it, and install new seals. No peeling, no corrosion.
Heres a tech tip for Mag Lights. Coat your batteries with Dow Corning DC33 o ring lube before you install them. Then if they leak, they wont corrode the flashlight tube.
