Flapping noise at high speed
smoreho2
Virginia
2023 XLT Hybrid (October 2023)
🤔 First off, I'm guessing that you do not have a soft tonneau cover?
I believe the post below shows the area between the outer fender and the inner fender where the insulation is. I hope this helps.
Good luck.
Thank you!
John Eplett
Port Perry Ontario Canada
2022 Ford maverick lariat
Don’t suppose you have a pic that would I’d where yours was in the door/fender do you? I want to make sure I am looking at the right thing. Still have the noise but what I checked was wedged fairly tight. Thanks for this info. Driving me crazy
These pics show the foam block, the empty cavity between the driver's door and the A pillar and the passenger side with the foam block in place
Ford Maverick Flapping noise at high speed 20241113_155831
The foam block that came loose and was laying on top of the inner fender beside the battery
Ford Maverick Flapping noise at high speed 20241113_155851
This is the driver's door side where the foam block sits
Ford Maverick Flapping noise at high speed 20241113_155912
This is the passenger side with the foam block still in place
