Does Maverick have Bluetooth?
QuesoEnFuego
Zach
Oregon
2018 Ford Fiesta
I assumed the Maverick had bluetooth at all levels but this youtube video points out that there is no bluetooth mention on any of the official Ford documentation. Anyone have any further info on this?
Thanks
Lappo424
NJ
Accord - Looking to switch to Maverick XL
I thought it was standard across all trims
theek
Michael
Ottawa Canada
Honda CR-V, Subaru CrossTrek
If it supports Android Auto it shoots Bluetooth
cbkcc1
SoFlo
Escape
Does it support wireless Android Auto/Apple CarPlay?
I assume so as it has a wireless charger.
balucipher
Balu
Coral Springs, FL
2021 Gladiator, 2021 Tesla Model Y
no wireless AA/CarPlay on Sync 3
I'm guessing they designed it to have Sync 4 and then chip shortages forced them to use Sync 3 for now
Amakrida
Alex
Indiana
Ford Maverick XLT Hybrid
balucipher
Balu
Coral Springs, FL
So it will be able to answer/make calls wirelessly, but to play music it will need to be wired?
Is this the same with the Lariat trim?
Wish they had a clear cut answer, seems ambiguous.
You'll have all the same functionality in the three trims. If you connect it by USB, calls and music are handled through CarPlay or Android Auto. If not, you connect to the Bluetooth in the headunit and it's handled by the system.
Amakrida
Alex
Indiana
To use Android Auto it requires a wires connection then, correct? Sorry. It's early, coffee isn't kicking in, and I'm not that bright.
Thanks for the reply.
theek
Michael
Ottawa Canada
Android Auto uses an Ethernet Over USB system to run the external touchscreen. That's a TCP interface and there is latency as you may notice with the touchscreen and with voice prompts. That's why voice prompts sometimes suck if your head unit is underpowered. They use Bluetooth to stream audio to get over the latency issue.
