D-Rings front of bed XL?
Ranchero
Wyoming
Ford Transit Connect
I have on order a '24 XL. I have never seen a Maverick bed in person; will do so for first time when the vehicle is delivered.
I want to add bed floor D-Rings in the position that Ford has put them on them on all other models of Maverick - one each side on bed floor at front of bed.
Question: Can after market D-Rings be secured with carriage bolts through bed floor to a nuts & washers under the bed? The two holes in the base for the D-rings are square so I can get the carriage bolts to grip. Can I get under the bed to put a nut/washer on a bolt? Or is the fuel tank in the way? Is there any access?
If there is no access and there is something under there, then what length of an M8-1.25 bolt can I use (once I've tapped the existing holes) without damaging the truck or hitting the fuel tank?
Thanks in advance.
Lane
Lane
Central Wisconsin
photos.app.goo.gl
2023 Area 51 Hybrid XL, 2006 VW Jetta Smyth UTE
Some good info is in these threads: #1, #2.
