Could someone explain all the data on the window sticker?
greenweever
Peterbuilt
There is a lot of data on it. What does it all mean?
greenweever
Peterbuilt
Thanks. My window sticker doesn't clearly indicate a blend date. Has it moved on the window stickers?
Bad Actor
Christopher
SE Missouri
01 Ranger XLT, 73 Mustang Base, 02 Toyota Camry
You don't have a date on the right, just under where it says Special Order? That is your blend date, or where it should be.
Edit - Yep, my bad. That is the invoice date.
greenweever
Peterbuilt
Ford Maverick Could someone explain all the data on the window sticker? 1665238577348
Looks like I have 10 06 22 and 10/08/2022 here. Which one is it? What are all these other numbers?
chuckles
Chuckles
Delavainia
crippled f150 10r80
Ah, no. That is the invoice date. The sticker does not seem to have a blend date anywhere.
The date centered in the white border on the bottom is the date the sticker (image) you are viewing was generated. Generating a new image tomorrow will have tomorrow's date.
