- First Name
- Michael
- Feb 5, 2025
- Glendale, Arizona USA
- 2025 Maverick XL
- Engine
- 2.0L EcoBoost
Hills? What are those?You can test this on a hill if it's really the parking brake.
Should shift one direction or the other the same way as using the parking brake.
I did find this in the web owners manual, which may be of interest.
Using Auto Hold
- Bring your vehicle to a complete stop. The auto hold active indicator illuminates in the instrument cluster display.
- Release the brake pedal. The system holds your vehicle at a standstill. The auto hold active indicator remains illuminated in the instrument cluster display.
- Apply the accelerator and drive off in a normal manner. The system releases the brakes and the auto hold active indicator switches off.
Note: Under certain conditions, the system could apply the electric parking brake. The brake system warning lamp illuminates. The electric parking brake releases when you press the accelerator pedal. See Automatically Releasing the Electric Parking Brake.
Note: While auto hold is applying the brakes, if you shift into reverse (R) or neutral (N) with your foot on the brake pedal, auto hold releases the brake. However, while auto hold is applying the brakes, if you shift into reverse (R) or neutral (N) without your foot on the brake pedal, auto hold continues to apply the brakes. In this case, the driver pressing the brake pedal causes auto hold to release the brake.
There could be actions that can cause the auto hold system not to work when the following occur:
- When you use trailer hitching assist.
- Your vehicle is in stay in neutral mode.
- The driver door is open.
- You shift into reverse (R) or neutral (N) before the system is active.
