C1 HitchMount LED Pod Reverse Kit For 2022+ Ford Maverick | Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
www.diodedynamics.com
Diode Dynamics is excited to offer our plug-and-play Stage Series HitchMount Reverse Light Kit for the 2022+ Ford Maverick!
Add significantly more light output when backing up at night with our Stage Series HitchMount Reverse Light Kit! This kit allows you to mount one SSC1 LED pod in your 2-inch trailer hitch receiver, adding a high-power reverse light and additional running light. The included harness plugs right into your factory tail light wiring for easy installation and operation.
Brighter Backup. Factory reverse bulbs just don't provide enough light output to back up at night confidently. By pairing our patented TIR optics with high-powered LEDs, the SSC1 LED pod included in this kit provides an additional reverse light that's several times brighter than stock bulbs alone. Plus, it automatically comes on when the vehicle is put in reverse!
Additional Running Light. The Stage Series LED pod included with this kit features a distinctive red backlight that can be used as an additional running light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in our Stage Series pods collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. Click here to learn more: Total Internal Reflection (TIR) Optics | Stage Series Video.
Functional Output. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
Everyday Operation. This kit is completely plug-and-play with factory connectors for the C1 LED pod. The included harness plugs right into your factory tail light wiring for easy installation and operation. The kit operates as an additional red running light with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. If you would like to have override functionality to manually turn on the reverse light anytime, you will need to purchase the universal backup harness.
Simple Installation. The patent-pending snap-fit design allows you to install this mount in minutes, without any drilling or need for a hitch pin. Simply insert the HitchMount into your trailer hitch receiver and the snap-fit side mounts will snap into place. Installation couldn't be easier and takes less than five minutes!
This kit is ideal for anyone who uses their trailer hitch often since removal can be done in minutes as well! Simply unplug the harness, press the snap-fit pins and remove the mount. When you're not using your hitch for towing, you can quickly reinstall the HitchMount and plug it back in.
Locking Pin Modification. If you would like to use a locking trailer pin to install this kit instead of the snap-fit pins, you can do so with a quick modification.
In the Box:
  • One (1) SSC1 Sport HitchMount LED Pod
  • One (1) C1 HitchMount Harness for Ford Maverick 2022-2024
  • Two (2) Zip ties
  • Installation guide
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
Click HERE to shop our C1 HitchMount LED Pod Reverse Kit for the 2022+ Ford Maverick!
Questions? We’ll be happy to help!
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
CTYankee
Central MA
2022 Maverick XLT
I had a really nice American Eagle snap-fit hitch plug. Operative word being "had". Someone else has it now because they pressed in the snap fit side mounts and walked away with it. At least with a locking hitch pin, I don't have to worry about losing a $120 light. It was smart to allow both methods of mounting.
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
In the Box:
  • Two (2) Zip ties
Phone: 314-205-3033
John C.
Diode Dynamics
Hi, John!
Will you guys be making the C1R pod for the hitch?
I wanted the brake lights to work also.
Cheers!
AzureBlueBill
Torrington, Connecticut
2024 Maverick Lariat / 1998 Mustang Cobra
Hi, John!
Cheers!
I'm not John, but I bought the C1R kit with the assumption it would work on my Lariat. Well it was not plug-and-play, and I was also advised by DD that there was no way to make it work on my truck, not even if wanted to start cutting/splicing wires. So I'd say it's doubtful they can make a C1R Maverick kit at all. Matter of fact if you look at the Q&A on DD's website they answered an inquiry by stating that they had no plans for it. DD customer service was awesome, and I already have a pre-paid return USPS sticker, and will be getting a full refund! That's pretty great service these days!
Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
Hi, John!
Cheers!
As stated by @AzureBlueBill we're unable to offer the C1R HitchMount at this time.
Sorry about that!
