Best fit bed cover. Tri-fold, rollup?
FlyingScot
Michael
South Florida
XLT Eco Lux FX4 4K CP360 HPR
Two questions on the hard roll-ups:
1) Can you stop anywhere along the roll or is it fully open/fully closed?
2) Which roll-up cover is the easiest to remove? Sure you can roll it up but it will still take up space at the front and occasionally need the full bed access.
The sentry needs to be rolled all the way up and secured with straps. Not sure if BAK or others have halfway roll options? would think with the design not possible. For 2 I would say definitely the Sentry - it has a latch under each side when rolled up you release then pull it up. very quick and easy
grumpyunk
tom
georgia
A low-budget tri-fold from The 'zon.
Ford Maverick Best fit bed cover. Tri-fold, rollup? IMG_20220629_093406583
Have not been out in the rain yet, but it fits well front-to-tailgate, and centered on the sides without any gap. The tension on the hold-down thingys is adjustable. The fabric is taught, and supposedly guaranteed for 3 years.
Not the best picture, but in person it looks nice, IMO.
I figured as often as I would need folded access, I can remove it in about 3 minutes, so am not worried about blocking the view aft.
If I really want a long-lasting cover after having this one, I will look closer, but felt this was "putting my toes in first" to see if it was something I liked.
About $230
tom
skadizzle
Orlando, Florida
2023 Ford Maverick Lariat BAP
Good to know the Sentry is quick to remove, but it just came to me about the roll-up needing to be all the way. I've seen some soft roll-ups using velcro to stay in place, but would be annoying if I need to roll it all the way up to access the bed for a few minutes.
FlyingScot
Michael
South Florida
Only needs to be rolled all the way up and straps connected when driving. When loading/unloading even on an incline you can partially roll as short or far as you‘d like. Really is a nicely designed cover, if not the best one out there.
Ford Maverick Best fit bed cover. Tri-fold, rollup? E5F8D017-FD91-476A-A6BE-B604F7379571
Ford Maverick Best fit bed cover. Tri-fold, rollup? 76ECC1DD-C5E4-461D-B151-7EB3E36A5DF4
Islandman
FL
Maverick Lariat Hybrid
Our Maverick Lariat came with soft Tri fold tonndeau from Ford. It was on an unpainted bed. I added a bed rug and a couple of wood pieces for the flex bed slots now it is perfect!! Have used it a ton! 1200 mile drive in windy conditions and no issues. It moves but does not flap! Some minor water drops but it is just fine!
Ford Maverick Best fit bed cover. Tri-fold, rollup? 22304DF2-1563-4800-B7D5-458161DB1E40
Ford Maverick Best fit bed cover. Tri-fold, rollup? E967103A-447E-4B07-9FDE-245D255D1DA0
Ford Maverick Best fit bed cover. Tri-fold, rollup? 69284C9D-DC40-4901-A5E7-0DE98040081F
BoxxerDad@50
Kip
Lees Summit MO
MY25 XLT BAP XLT HYBRID SOLD MY 2023 XLT hybrid 2023 Lariat,MY22XLT
I have not had any water issues in the bed. This cover has heavy-duty matte black aluminum slats that are pressure-bonded to the fabric. There are built-in rubber seals in front, underside rails, and rollup header bar designed to keep your cargo dry. My daily drive to work is mostly interstate travel and I don't experience flapping with this cover. The slam latch, security latch in the center of the cover and the flow-profile design keeps the cover secure while traveling.
brand?
Nashbar105
Frank
Ram 1500
I got this on Amazon for $700, hard tri-fold which was easy to install and has the quick release open. Xcover is the brand.
Ford Maverick Best fit bed cover. Tri-fold, rollup? 20230218_140222
Brutus
St. Louis, Missouri
Truxedo Sentry CT Tonneau Hard Rollup Cover
Ford Maverick Best fit bed cover. Tri-fold, rollup? Image 1
