Bedliner shop sprayed my threaded inserts.. Can someone identify the thread spec?
Geoff
Fort Collins, CO
2022 Maverick, EB AWD Towing, Cactus Grey
Well, they did a great job other than spray a good 1/2" into all of the threaded ports in the bed of my XL. I intend to use these someday so I'm going to need to run a tap through each of them. Would anyone be kind enough to pull one of the bolts and ID the thread for me?
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
I suggest you use a rethreading tap rather than, well, a threading tap. A rethreading tap is designed to clean and restore existing threads, whereas a threading tap is designed to cut new threads.
You can use a threading tap to clean and restore existing threads, but the threads will probably be loose as a result of being essentially double-cut. This increases the chance of the threads stripping out entirely when a fastener is inserted and tightened down.
The same thing happened to me when I got my F-250 Line-X'ed. I was able to scrape away material with a box knife, use a slightly-too-small drill bit to clear out the nutserts, and use a rethreading die to scrape the threads clean.
