Backup Camera Takes Too Long To Display
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
Concur, same with mine, near instant. However, I not sure if it makes a difference with or without LUX Pkg / with or without Sync 3
Mine does have the Lux package but being an XLT does not have SYNC or Nav. Wondering if anyone with similar setup is experiencing this issue.
In fact that's my biggest gripe about the Maverick, the stereo. I'm not even talking the speakers. That touchscreen system is super laggy, unresponsive, and you literally can't scroll at all while moving (any way to disable that?).
Dutiful Don
Don
Tucson
2022 Lariat Hybrid
If I start the vehicle and shift into reverse, the delay is about 5 seconds, however if I wait for the display screen to finish loading, the delay is almost negligible.
BlackMav23
MI
While I would say that everyone should let their vehicle warm up and not be in such a rush... that loading screen takes way too long and is unacceptable.
Modern vehicles do not require a lengthy idle before driving. I typically use the remote start this time of year. The vehicle idles down in no time at all. But as soon as I turn the key... that dreading loading screen from cheap head unit. I should test and see if allowing it to complete changes the behavior of the camera load.
Regardless, something sold as a convenient safety feature is frankly unsafe if it doesn't function when the vehicle is ready to perform its function.
Vols44
Missouri
2018 Edge
Rebooting the infotainment screen (pressing the power and skip forward buttons at the same time , for five seconds) is a common method for all modern Fords. Shutting off the vehicle and restarting it a couple of times has also helped.
BlackMav23
MI
Unfortunately it's not frozen, it just takes way too long to fully load.
Vols44
Missouri
2018 Edge
I check my truck's software version R22075A and made sure the back up camera delay feature is off. In a forum for a different Ford vehicle it stated that the camera stays on until the vehicle exceeds 3mph in drive.
BlackMav23
MI
That's referring to a delay when shifting out of reverse into drive, which can of course be disabled.
The issue discussed here is the inconsistent wait time for the rear camera to display in dash after shifting into reverse.
