Anyone removed the headliner from their Maverick?
hikonhui
kon
San Francisco
tundra
Has anyone removed the headliner from their maverick? I wanted add butyl and mass loaded insulation. Was wondering if there is enough space available to install this. Thank you in advance.
TedTX
Ted
San Antonio TX
A guy redoing the brake light on the back of cab did and recall it was held up by lots of trim. Don’t think you will like the result. There are many other areas to sound deaden before there.
WW-hiker
Va
2022 Maverick XLT Hybrid
I wish someone would post photos of underside of roof with headliner removed. I want to drill roof and install roof rails (as Ford should have done) using nutserts so headliner removal will not be necessary. Also can verify any reinforce areas or things in the way such as wiring or airbags! I read elsewhere that drilling for roof rails could damage airbags. Local Ford dealer is zero help. Any help or info would be appreciated. I am not interested in any clamp on roof rack options.
Thanks.
Wilbur
Scottsdale, AZ
1967 Ford F100
I am also interested to see or watch the results of a headliner removal.
hikonhui
kon
San Francisco
tundra
WW-hiker
Va
Thanks Wilbur. The photos give me an idea of where those air bags and wiring are. Doesn't look like any reinforcements or supports except between the door posts. They have to remove headliner for the airbag recall. Wish I could jump in with my drill while the liner is out. Guess that would be too easy.
