Sold: Washington $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware
Hybrid25XLTAWD
Jeff
WA
25 XLT AWD Maverick Hybrid (ordered)
Originally purchased these to use as auxiliary backup lights, but due to my mounting location, found that thery were a bit too large &couldn't be aimed up at a great enough angle (no use having backup lights that point almost straight down?)
These are the sport model with the combination beam and red backlight (backlight does NOT need to be hooked up if, for instance, you wanted to use these as a front-facing light)
Also included is a security hardware kit to lessen the chance of your lights being taken by others (lessen because we all know if someone REALLY wants them, nothing is going to stop them from taking them)
everything is as it was received from DD, nothing missing, never been installed.
I;m running a pair of these on the front (with amber backlighting), using the DD ditch light brackets & they are plenty bright for my needs.
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4244
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4250
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4251
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4249
Hybrid25XLTAWD
Hybrid25XLTAWD
Jeff
WA
bump
BearyArizona
Jack
Phoenix
24 Maverick XLT
So these are the front lights as well as a red backup light? Or do they just happen to have some red that you can turn on on top of the white?
Hybrid25XLTAWD
Hybrid25XLTAWD
Jeff
WA
Front or rear lights with an optional red backlight.
The attached image is of the same brand and model oflights, only with the amber backlight that I have installed on the front of my truck. Using the red back lighting on the front of your vehicle is probably illegal in most states.
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4111
Ford Maverick $250 BNIB Diode Dynamics SS3 Sport Pod Set with red backlight and security hardware IMG_4112
Hybrid25XLTAWD
Hybrid25XLTAWD
Jeff
WA
bump
