12v pigtail fuse location
bpcooper14
'08 Nissan Frontier
I looked through the owners manual last night and probably overlooked it. I blew the fuse that the 12v pigtail is connected to and can't figure out which one it is/where it is located. I know it's in one of the fuse boxes. Lol Thanks in advance!
CSmith
CJ
Southern Indiana
2022 Maverick XLT FX4, 2020 F150 XLT FX4
This link has great fuse info.
https://fuse-box.info/ford/ford-maverick-p758-2022-fuses
I believe, but haven't confirmed, that it is the 20amp fuse #84 in the under-hood fuse box. Take a look and see if that one is blown.
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
It’s 80 something. I believe it’s under the hood and not the dash.
Learned a few weeks ago after installing led bed lights. Also learned nothing was wrong, it just automatically turns off after a set amount of time
bpcooper14
'08 Nissan Frontier
Awesome! I'll have to give it a look later. Been under the weather and had family in during the holidays so just getting around to it.
bpcooper14
'08 Nissan Frontier
Had some time to get under the hood last night. Let me start off with, I hate that fuse box. Talk about over engineering something. Anyway, I looked through, pulled the fuse that we all thought was the offending one (84) but it appeared to be fine. I even swapped out another fuse in it's place to see if that was the issue and I couldn't recognize that it was blown.
Now, I'm going to have to go through all of the fuses to see if I'm able to identify which one it is that needs to be addressed
TheWizziard
Texas-RGV
If fuse #84 is "OK" then a blown fuse may not be the problem.
I assume you know the Pick-Up Bed Power Points are switched with the ignition.
Let us know what you find.
bpcooper14
'08 Nissan Frontier
I think I may have overly an inline fuse somewhere along the way. I'll drive into the wiring I have back there after work tonight and see if that's the culprit.
22Mav805
Vic
So Cal
Did your ever find the location of the fuse, i have the same problem and can't locate the fuse that's blown.
bpcooper14
'08 Nissan Frontier
It ended up being an inline fuse that blew. Swapped that out and I haven't had an issue since.
bpcooper14
'08 Nissan Frontier
Jjpreston55
JP
Southern California
2023 Maverick XL Hybrid
I have the same problem, but cannot find an inline fuse that you mentioned. Where did you find that fuse specifically? I appreciate any input. Thanks.
svllcn
23 XLT Hybrid
Did you resolve your problem? I’m running into the same issue. Fuse #84 under the hood isn’t blown but I have no power to the pigtails.
