Muslogy Bed Mat, love it
Benilla
Edmonton
Was quite happy with the Muslogy stuff so far so I bought the bed mat. I have a drop in but when I do dump runs, unfortunately some of the garbage juice leaks which requires a spray down which worries me that water will get under the drop in and rust. Tbh I should remove the bottom of the drop in and just use this because it's easily removable. There is a part you can cut open so the bed hooks can come through but I almost never use those so I think I'm gonna keep it 1 piece. High quality rubber material, I can see this lasting a very long time .. decently high sides too!
Ford Maverick Muslogy Bed Mat, love it PXL_20240629_171500520
Ford Maverick Muslogy Bed Mat, love it PXL_20240629_171510464
Benilla
Edmonton
So I just spent a few hours removing the bottom part of the drop in bedliner and discovered a couple of surface rust spots forming! I have a 2022 and I'm convinced if I left it, it would have developed into something bad. Muslogy bedmat FTW so I can remove it whenever to clean up underneath very easily
rclee
Rob
Dayton Ohio
I like my bed cover, but I have a spray in liner too. I like the fact I can just pull it out and dump whatever is in the liner. I think mine is a Mabbett.
Cocobean
Carol
New York
2023 Ford Maverick XL
I have the same one and love it! Excellent quality material. I had to leave it in the sun a bit when it first arrived since it was folded in a box. It flattened out and fits perfectly in the bed 😊
Unkechaug
Maverick XL
@Benilla @Cocobean How heavy duty is this mat? Amazon's webpage says 11 lbs, which seems pretty light for a bed mat like this. It looks pretty nice but the Rough Country one is more than double the weight.
Benilla
Edmonton
I think the rough country one is more indestructible (it's basically a cut out gym mat) but you'd have to worry about water going underneath it because there's no sides.
I'm not sure what you would be carry in your bed that would puncture the Muslogy one though
Cocobean
Carol
New York
I agree, I find it to be quite heavy duty - this mat also fits perfectly so there’s no movement either
Ford Maverick Muslogy Bed Mat, love it IMG_7380
Unkechaug
Maverick XL
Not concerned about puncturing, just about weight so it doesn’t lift or risk flying out on the highway.
Cocobean
Carol
New York
Not at all likely since it’s contoured perfectly to fit the bed…
