California Lowering springs and SOLID sway bar
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
2022 through 2024 Ford Maverick *Brand New in the box* Lowering Springs AND solid (not hollow)adjustable rear sway bar with bushings
Everything in the picture(s) is included.
*** FOR AWD ONLY ***
Keep the nice ride, have a better look, and better handling. Lowers your truck 2” in the front and 2.6” in the rear. You’ll still be able to load, and use it, as a truck.
The result is a lighter weight spring, better ride, lower unsprung weight with minimal coil contact
Front spring rate: 175 pounds
Rear spring rate: 400 pounds
Stock rates: Front: 148/ Rear: 338
The springs are double coated and have the best resistance to corrosion in the industry.
Unlike other hollow sway bars on the market, this adjustable sway bar is SOLID. New bushings and brackets are included. It will not crack in half. I personally had the hollow one and it snapped in half after about 6 months of normal use. I have this solid Good-Win Racing rear sway bar on my Maverick for about 1.5 years and it’s still great. Better handling and obvious less body roll.
Items are Brand New in boxes.
I will ship the next business day after payment
I don’t sell many things, but when I do, I alwaaaays tell the good AND the bad (if any). I’d truly rather not make the sale, than have an unhappy buyer. In this case, there is nothing bad to say about the items listed.
$400 shipped to lower 48
Thank you for looking
Ford Maverick Lowering springs and SOLID sway bar IMG_1050
Ford Maverick Lowering springs and SOLID sway bar IMG_1051
CurtisB
2023 Maverick XLT Hybrid
This deal won't last!!
Fred H
Fred
2025 Maverick Lariat (on order)
I doubt that it will last long
Thanks
Hi Azmig88, If you still have your springs and sway bar for sale can you send me a direct message? Thanks, Fred
