- First Name
- Gary
- Apr 16, 2021
- New Lenox IL
- 2022 Maveriak Lariat, 2021 Mach e
- Engine
- 2.5L Hybrid
Probably!!
Check out my post on how I used The stock ambient lighting from a wrecked 15 to 22 mustang..super easy and you can choose between 3 colorsProbably. However, I've already DIY'd the ambient lighting in the console and front foot wells. Also, the Ford factory lighting (at least in the console) is a 3-wire layout that requires a canbus signal to operate. I have no proof, but I believe they are universal across all Ford products and contain the ability to change colors. See below...
There probably is a setting that would allow it. However, there is no wiring that would allow it, so you'd have to rewire it anyway.
The F-150 guys have a few posts about how to wire ambient lighting and reprogram the APIM. They've also figured out that they are color changing. However, I believe that would require the use of sync 4. Here's some references: https://www.f150forum.com/f129/adding-ambient-lighting-2021-a-502078/
https://www.f150forum.com/f118/oem-...lt-mft-controlled-success-361075/#post4998002
