Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
www.diodedynamics.com
If you’re looking for full command over your lighting and 12V accessories at your fingertips, Diode Dynamics has you covered with the all-new D-Switch 8-Channel Switch Panel. This advanced automotive switch panel is packed with features to take your setup to the next level—whether you’re building out an off-road rig, overlander, or show vehicle.
Engineered from the ground up with lighting in mind, the D-Switch delivers everything you’d expect from a high-end auxiliary light switch panel, plus some industry-first capabilities that put it in a class of its own.
Dedicated Backlight Channel. While there are many 8-button controllers on the market, the D-Switch stands apart with a 9th button dedicated to the backlight bus bar. The backlight bus provides eight extra outputs for your accent lights, allowing you to connect all of your backlit accessories without using up any of your main outputs. With just the press of a button, you can now activate all of your backlights at once! This is a game-changer for any rig with multiple lights installed.
Dynamic Channel Assignment. The Diode Dynamics D-Switch is designed to give you complete control over your vehicle’s setup with eight customizable output channels. Unlike traditional switch panels that are one-to-one, meaning Channel 1 is always tied to Button 1, the D-Switch allows you to group and configure multiple output channels per button, allowing you to control multiple outputs with a single button.
You can also power a single output with the different strobing patterns that are included. For example, you can program one button to strobe a light and another to run that same light at full power. Whether you're running Diode Dynamics off-road lighting or any other 12V accessories, the D-Switch allows you to customize each button to do exactly what you need.
Fast, Responsive Bluetooth App. To activate and use the D-Switch, you can use the included controller, or control it using your phone through the Bluetooth App. That’s where you’ll configure and customize things as well.
Say goodbye to switch panel apps that lag, freeze, or don’t connect. The D-Switch Bluetooth app for iOS and Android delivers instant response and easy programming with no loading screens or connection delays for a seamless and fast experience, every time.
OEM Signal Integration. The D-Switch includes four trigger wires, along with a dedicated Ignition wire for added flexibility. This allows you to control your whole setup using vehicle signals, for a completely integrated experience.
The ignition wire can be wired into an OEM ignition source and will activate the D-Switch when the ignition is turned on. It will also shut things down when the ignition is turned off. No need to manually turn your panel off! If you want to use any outputs without the ignition turned on, no worries - you can still turn the controller on manually at any time.
The three trigger wires provide seamless integration with any of your vehicle’s 12V factory signals, such as high beams, fog lights, or reverse lights. This allows you to activate your outputs automatically–no buttons or switches. With some simple programming, your entire setup can operate like it’s fully integrated on your vehicle.
Lastly, the Night Mode wire can be used to activate certain outputs, such as dimming outputs, or adjusting settings for low-light conditions. This trigger also adjusts the brightness of the controller’s backlighting automatically when driving at night.
Solid-State, Durable Design. Built for extreme durability, the D-Switch features a solid-state design with no mechanical relays to wear out, or physical fuses to replace. The hub is encapsulated with an aluminum heatsink, ensuring superior heat dissipation. The D-Switch is IP67-rated for weather resistance and is backed by a 3-year limited warranty, ensuring long-term reliability and performance. Whether you're off-roading or on the road, it’s built to withstand whatever you throw at it.
In the Box:
  • One (1) Switch Panel Hub
  • One (1) Switch Panel Controller
  • One (1) Controller Universal Mounting Bracket
  • One (1) 10-foot Controller Wiring Harness
  • One (1) Trigger Wires + Night Mode Wiring Harness
  • One (1) 3-foot 4AWG Battery Cable
  • One (1) 3-foot 4AWG Ground Cable
  • Two (2) Button Sticker Sheets
  • Five (5) T-taps
  • Six (6) Zip Ties
  • Double-sided tape
  • Installation Hardware
  • Installation & Programming Guide
Channel Power: Channels 1 - 4: 15A (per channel), Channels 5 - 8: 30A (per channel), Backlight 15A (total)
Max Current: 125A
Electrical Compatibility: DC
Operating Voltage: 9-16V
Wire Size: 4AWG (Battery), 22AWG (Sensors), 26AWG (Controller)
Operating Temperature: -40C to 120C (-40F to 250F)
Materials: FR4 PCB, Aluminum Casting, ASA Plastic
Cooling: Passive, Pin-Fin heatsink
Intrusion Ratings: IP67 Weatherproof
Product Dimensions (in): Controller: 5.06" x 2.66" x 0.45", Hub: 8.33" x 6.26" x 1.79"
Unit Weight (lb): 1.9
Product Weight (lb): 4.7
Shipped Weight (lb): 5.6
100% Satisfaction Guarantee
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer our own products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns. Please go ahead and give us a call at 314-205-3033, Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our in-house US service team would be happy to help you with that.
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: [email protected]
Phone: 314-205-3033
Forum Exclusive. All forum members are eligible for a free US shipping code by sending us a direct message.
John C.
Social Media Community Manager
Diode Dynamics
Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
There will be vehicle-specific mounts available in the future for both the hub and controller. Additionally, many of our partner brands working alongside Diode Dynamics will offer their own mounting solutions!
For example, Bulletpoint Mounting Solutions is already prepared with a switch panel mount designed specifically for the upcoming Diode Dynamics D-Switch 8-Gang Switch Panel.
The mount features all-aluminum construction, ensuring both strength and lightweight durability.
It will be available in two versions: one with a 20mm ball and another with a 20mm connector end.
For more details, visit: Bulletpoint Mounting Solutions
Abel7847
Abel
Dallas
Loved that roof rack with ss2, will there be something for Maverick as well?
Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
Hey there!
The DEK Rooftop System is by Kuat. That will be for select vehicles when it becomes available. We advise contacting Kuat directly to find out if they have plans for the Ford Maverick.
[email protected]
Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
Sorry ,$599.95, hard NO. Love it though
That's understandable if you're not in the market for a premium switch panel. Thanks for taking a look and for the support!
tkammen270
NNJ
2025 Ranger Raptor
When I saw the price yikes. I think more companies should make a single row panel. Much easier to fit in smaller cars and trucks. My 6 switch panel fits like a glove above the rear view mirror.
Diode Dynamics
Diode Dynamics
Diamond Sponsor
John C.
St. Louis, Missouri
We'll pass this suggestion along to our engineering team. We might be able to bring more controller options to the market, as it simply plugs into the hub. However, please note this is not guaranteed but a suggested request for the team to review.
tkammen270
NNJ
2025 Ranger Raptor
We'll pass this suggestion along to our engineering team. We might be able to bring more controller options to the market, as it simply plugs into the hub!
Awesome! Having some controller options would be great!
nunucello
Marcello
New York
I like it !
TRUCKHEF
SOCAL
22' Ford Maverick XLT
Completely unrelated but whennnnn are you guys going to release headlights/taillights for the Maverick??? 🙈🙊
SouthbayTremor
Matteus
Los Angeles
2024 Ford Maverick Tremor XLT, 2018 Mazda3
Auxbeam does this for 1/3 of the price! Hard pass. I like your ditch light mounts for the maverick! Good price too but the switches for $600 yeah no thank you
