I wanted to do a few minor add ons to make it mine. Added a genuine Ford bed cover, hood graphic and all weather floor mats.
- * *Hood graphic direct from Ford, part# VNZ6Z-6320000-C. Easy install with patience. BUT- do not install dry. Thoroughly clean the hood and wipe down with grease and wax remover. Then spray the area water and a few drops of dish soap added in. This gives you the opportunity to center it and slowly work out the bubbles and creases. The hood is not flat and installing dry will be a disaster
- ** Ford bed cover, part # VNZ6Z-99501A42-B. Great quality, supports built into the cover and an nicely embossed Ford oval on the vinyl. Took about 20 minutes to install.
- ** Weathertech all weather floor mats. I bought these since I like the fact they are made in USA and have always been satisfied. But I recommend NOT to buy these. One of the dirtiest areas is by the gas pedal, these have no mat in that area. By the heel area there is a hump in the Maverick floor, the mat is flat and had to stretch the mat to clip on the right stud. They also had some extra material molded on for hanging in a display. Instructions say to cut it off, no matter how careful it looks like hell.
- ** discounts on Ford parts. Check AutoNation Ford at White Bear Lake. They have a great website for Ford parts and are usually about 20% under every other dealer. The bed cover lists at $369.00 and they had it at $309.00. Great service and I have bought from them for years. Shipping is not an issue.
