Maverick Amateur Radio Club
Amateur Radio Mobile Operation
wb5oxq
I have discovered a problem with the charging circuit. When there is no electrical load such as headlights, A/C etc the charging circuit is mostly off. Battery voltage shows 12.5 volts. turn on the headlights and it goes to 13.8, same with A/C. with every accessory turned off I get under 12 volts to the radio and amplifier when transmitting. Turn headlights on and I get 13.5. How can I get the truck to detect the load on the radio power cable?
Show full message↓
  • Like
Reactions: Mr Lee
Mr Lee
Hi, new member here...Just wondering are you speaking of directly drawing the power from the battery? Because even if the alternator doesn't maintain a constant charge voltage I'm sure the battery itself has to be relatively stable. Also I'm sure the charge circuit will kick in if the battery gets low.
5,413
