Will the FX4 shocks/struts swap to the Hybrid?
No 4k on the FWD is more likely due to the front end (un)loading concerns. After all it was an orderable option that did very nearly make it to production.With that said those springs and suspension differences are what keep FWD vehicles from having a 4k tow option and AWD being offered on the hybrids.
The front ends also use different roll bars for FWD rear force vector spring suspensions vs the standard rear coil spring suspensions on AWD vehicles. With that said if it wasn't a limiting factor for 4k towing then the FWD 2.0L ecoboosts should have at least gotten the option for the upgrade on the final revision which they didn't.No 4k on the FWD is more likely due to the front end (un)loading concerns. After all it was an orderable option that did very nearly make it to production.
