why is there a 12 volt battery in the hybrid
hondabuster
Andy
Minnesota
Rav hybrid ,tacoma
Sweet Willie
New Bern, NC
1999 Toyota Camry
Interesting, thanks for posting.
ItsaMaverick
Massachusetts
This is the same in a tesla. There is still a 12v lead acid battery that is mission critical. The car will not operate without it. I found it very strange.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Anyone remember when distributors had points and a condenser? The "points" were switch contacts running on a cam so the switch opened and closed once for each cylinder on each engine revolution. Opening and closing the 12v circuit caused the ignition coil to produce a high-voltage pulse that made the spark plug flash. You know what happen next.
I only mention it because hybrids also have "points" that could fail the same way they did in our distributors - corrosion. Making/breaking electric contact draws an arc, and that arc can damage the contacts.
The HVB is disconnected when parked. When you open a door, the 12v system energizes a step-up system that energizes the HVB contacts on the load side. When the contacts are closed, there is no arc because there is no voltage difference. That's very reliable.
So... Tesla needs a 12v, too.
Rkbrumbelow
Robert
Cedartown, GA
HCH2, Hybrid XLT on order
Basically, it comes down to a lot of things are designed for 12v
car makers are conservative by nature and do not want to deal with 2nd and 3rd party suppliers having to account for more voltage variables
Fish Chris
Sacramento California
Prius LE, Ford F150
So far as I know, all hybrids have a 12 volt battery as well. What they don't have, is an alternator. Instead, power from the big battery is regulated down to 12 volts (or 14.5), and then used to keep that battery charged.
Rkbrumbelow
Robert
Cedartown, GA
My HCH2 still has an alternator/generator I threw the big red don’t touch me switch 3 years ago. However it means it only effectively charges in the 2.5k RPM range (which may be using the IMA as a generator come to think of it) yeah cargurus says it’s the IMA doing the charging. Though they are wrong about the car not driving without the big battery. I still get 36mpg and the circuit has not only been turned off the battery is physically disconnected.
jimmy fitzwell
jimmy
troy, mt.
73 pinto wagon, 67 olds 98
One of the original EVs, the 2011 THINK City Car, bit the dust because of arc-flashing. Quick cycling the key with the heater left on completely destroyed it.
High voltage DC is the future (cars, heat-pumps, solar... etc.) so be careful with hacks.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Hf45-based hybrids use a DC-DC converter to supply low-voltage DC, as well as the AC inverter for the AC-DC-AC conversion.
Other hybrid systems, as in the Explorer, may have conventional/beefed-up belt driven alternators.
es7129
Ed
Long Island
Our Hyundai Tucson Hybrid Blue also has a 12v.
clavicus
Afaik, for one thing, the high voltage battery is physically disconnected via contactors when not in use. The 12v battery provides power to magnetize the contactors.
12v battery may also power certain other accessory things when the hv battery is in this disconnected state. I'm assuming that's stuff like modem, computer memory, security system, etc?
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Thinking about it, both cab and bed outlets offer 400W of 120v power as I recall. That's a high current draw for a typical car battery. I'll wager they use the HVB, and that's something very unique. The C-MAx did 100W, the Escape, 150W.
slashy42
The 2.0 has the same 400w inverter.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
I wonder if its engine will cycle on periodically, like the hybrid does when you're parked running AC.
If the HV battery is low on charge the gas engine will start and spin the generator motor to charge the HV battery. This can happen with the truck stopped, parked or moving.
The HV battery powers the AC so if enough charge is in it the AC will run with the engine off.
