Washing the hybrid engine?
XL Hybrid Cactus Gray
United States
2022 Ford Maverick Hybrid XL
From Ford's 2025 Ford Maverick Owners Manual and Webpage:
Cleaning the Exterior - Cleaning the Engine Compartment
Use a vacuum cleaner to remove debris from the screen area below the windshield.
Note: If you are not familiar with the parts around the engine do not wash the engine compartment. Avoid frequent engine washes.
When washing the engine compartment:
Never wash or rinse the engine while it is hot or running.
Never wash or rinse any ignition coil, spark plug wire or spark plug well.
Cover the battery, power distribution box, and air filter assembly to prevent water damage.
Note: If your vehicle has an engine cover remove the cover before application of shampoo and degreaser.
Spray an approved engine shampoo and degreaser on all parts that require cleaning and rinse with water.
https://www.fordservicecontent.com/...A&div=f&vFilteringEnabled=False&buildtype=web
Similar answer from the Ford AI search bot:
How to wash a hybrid engine?
When washing the engine compartment of your 2025 Maverick Hybrid:
WARNING : Never wash or rinse the engine while it is hot or running.
WARNING : Never wash or rinse any ignition coil, spark plug wire or spark plug well.
Use a vacuum cleaner to remove debris from the screen area below the windshield.[1]
If your vehicle has an engine cover remove the cover before application of shampoo and degreaser.[1]
Cover the battery, power distribution box, and air filter assembly to prevent water damage.[1]
Spray an approved engine shampoo and degreaser on all parts that require cleaning and rinse with water.[1] Motorcraft® Engine Shampoo and Degreaser, ZC-20 (U.S.) or Motorcraft® Engine Shampoo, CXC-66-A (Canada) can be used.[2]
Note: Follow the manufacturer's instructions for using engine shampoo and degreaser.[1]
Note: If you are not familiar with the parts around the engine do not wash the engine compartment. Avoid frequent engine washes.[1]
Our AI referenced this information:
Vehicle Care | Cleaning the Exterior | Cleaning the Engine Compartment
Vehicle Care | Cleaning Products | Materials
https://www.ford.com/support/owner-manuals-details/intelligent-search
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
I'm with Scotty on this one. I don't wash my engine (anymore), I use a leaf blower and that's it. Not gonna take a chance on shorting something from water. I pretend the label says Dry Clean Only, lol.
CurtisB
2023 Maverick XLT Hybrid
Just use the "spot free rinse" option at your local self use car wash every 6 months. I have done this with every car I have driven going back to 1974..........never had an issue.
Using high power wash on an engine is asking for problems.
YazYaz
Northeast
2019 Ford Escape
Anybody washed their hybrid engine? Is their do’s and don’ts?
I spray wash mine all the time. Sometimes at a car wash or sometimes at home with a garden hose. Very light pressure. (I do cover the fuse area) Spay with a cleaner. Agitate with an appropriate soft engine brush. Spray rinse. Finish with a no wipe engine finish.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
From an earlier post of mine. I have a 2.0 though.
Cleaning engine compartment
My motor washing since 1970s 1st. Start motor 2nd. Spray all parts on motor with Gunk original 3rd. Wait 7 minutes 4th. Pressure wash motor 5th. Let run for 15 minutes till dry 6th. Turn off and restart
computerpulse
Edward
2023 Ford Maverick
^Note the manual is written generically for various models and engine types.
No real concerns for the hybrid. Don't unplug the orange cables and treat it like any other vehicle.
is this your truck I see suds upped?
God bless you, but there’s a lot of high voltage areas in this compartment
dochawk
doc
Las Vegas
Washing it is easy.
It's manhandling it onto the line to dry that takes really effort!
CNJFF
NJ
Yes it is mine. I took that pic solely because of another thread where people were worried about "high voltage" and warranty blah blah blah. It's not sealed. It's not delicate. Nothing is going to shock you. It's a vehicle made to be out in the elements. If anything the hybrid has less to worry about since there is no battery or alternator under there.
Again, don't unplug the orange cables and you'll be fine.
LSchicago
Lloyd
IL
I have a little trick I used for my Show Tow Truck.
This was the truck I'm mentioning:
Ford Maverick Washing the hybrid engine? Screenshot_20260104_053316_Gallery
Before a show, I'd spray the cold engine down with armor all tire shine. Let it drip off, then use a rag to wipe off any droplets. Looked better than new, and got that first place trophy.
WARNING ⚠
It is flammable, so do not spray on a hot engine. No issue running it after it dries.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Not my truck , but in 2 years I have washed twice, then spray a tire shine on it for all the plastic parts to pop, next time I do it I will take pics and put on MTC
Mine will go to a detail shop we all use.
On the way to the ford dealer to trade it for a new one.
Until then a leaf blower cleans my engine bay up just fine.
