Looks as if the supplier that manufactured and assembled the Loooonnnggg battery cable messed up on some of the connectors. They should be soldered to the wire and likely also have the connector crimped.
The solution of replacing with a new harness/cable is the only one available at most dealers because the soldering equipment needed to solder such a large connector is not available at most dealers.
A workaround or fix would be to use a gas/propane powered soldering iron. They are large-headed soldering irons with a handle that are heated in a Bernz-O-Matic flame or if permanent, a natural gas flame. In the past, radiator shops had them avaiable. The head can absorb a lot of BTUs and will transfer enough to get the connector, cable and solder fully heated. An electric, hand-held soldering iron just does not have the capacity to heat all the parts hot enough.
If there is a radiator repair shop that can re-core radiators, or repair radiator tanks(brass type), it could also likely repair these poorly soldered joints without need to replace the whole thing. Nice solution in case they are back-ordered, which I expect they are.
tom
tom
