- First Name
- Michael
- Jan 11, 2021
- Ottawa Canada
- Honda CR-V, Subaru CrossTrek
- Engine
- 2.0L EcoBoost
So, is this coming to the Maverick too?
Off-road traction
More than traction control, new AWD systems are getting very good at optimizing traction. Take for example the Bronco Sports optional AWD system. Supplied by DANA, it’s an on-demand AWD system. The Bronco Sport with this system uses a cooled Power Transfer Unit or PTU that attaches to transaxle and sends power to the Rear Drive Unit, or RDU.
Bronco Sport’s class-exclusive twin-clutch rear-drive 4×4 system with differential lock feature. The system can divert virtually all rear axle torque to either wheel.
The RDU has 2 clutches, one on each axle shaft that takes the torque from the prop shaft and distributes it to the wheel that needs it. These 2 clutches handle front-to-rear as well as side-to-side speed and torque biases, effectively eliminating 2 differentials, the center, and rear. When AWD is commanded, such as when the “center lock” button is pressed, the 2 rear RDM clutches engage at the same time, allowing torque to go to the rear axle. When turning sharply, the computer partially disengages the clutch on the inside wheel of the RDM allowing it to slip to deal with the speed difference a differential would normally handle. When you “lock” the “rear diff” you are commanding more pressure more often to those clutches. The buttons are programming tricks to tell the computer you prefer traction over smooth on-road driving but “lock” nothing, not really.
Even when “locked” the systems will know to allow the required slip for turning for example. Despite this, the system is very effective, allowing for at least half and probably more up to 70% or so of the engine torque to go to the rear axle and “almost all” that torque to go to a single rear wheel according to Ford. The front differential is your run-of-the-mill open type and is managed through braking individual wheels to simulate traction on a slipping wheel and allow more torque to go to a gripping one.
Off-road traction
