Tool Storage - HF’s Mini Tool Chest
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
I have always maintained a minimal tool kit for roadside emergencies in each of my vehicles. Usually, that has meant a canvas tool bag thrown into a corner of the trunk. I had a similar set up for my Maverick until recently.
Harbor Freight has introduced an item that that I welcomed to replace my well worn canvas tool tote.
Their Mini Steel Tool Box has a top compartment and two ball bearing slide drawers, each with a rubber drawer liner. Size-wise, the mini tool chest is perfect for dropping into the under the rear seat compartment on the driver’s side of my hybrid.
I have the top compartment
loaded with a screwdriver set and a pair of slip pliers. The first drawer holds a 1/4” deep socket set with ratchet breaker bar handles. The second drawer is for a metric open and box combination wrench set. Separate from the tool box in the same under the seat location, I have an inexpensive cased 3/8” socket set and a plastic utility case for my tire plugging items. I like the convenience of HF’s product and recommend it as an accessory to other Maverick owners. Also, I would be interested in hearing what others believe are appropriate for rounding out my tool selection, perhaps a set of Vise-Grips?
Ford Maverick Tool Storage - HF’s Mini Tool Chest IMG_2190
Ford Maverick Tool Storage - HF’s Mini Tool Chest IMG_2187
Ford Maverick Tool Storage - HF’s Mini Tool Chest IMG_2191
matmondro
Mathieu
Vassar, MI
Nice setup! A pair of vise-grips and perhaps a pair of needle nose pliers might be a good addition to your kit. Also, that set of cheap HF picks with the plastic handles, usually near the check-out, might be worth grabbing too. Can't tell you how many times I've used them working on my cars and sleds.
Gpp
Gil
Sanford nc
2022 ford maverick
By all means get vise grips,two,yes two 10 mm wrenches and 10 mm 1/4 drive sockets!.maybe a tape measure.yoo could keep on but you will run out of room.
tkammen270
NNJ
2025 Ranger Raptor
I love the little tool boxes. I have a few and the HF ones are much better than the Kobalt ones. I picked up a Boxo tool roll to keep in my Maverick.
LBCOX
Larry
NM
2024 Mav Hybrid
It was hard for me to visualize that "big" tool box fitting under the seat, so I went to HF...here's the specs:
Specifications
SKU(s)72431; Brand - U.S. GENERAL; Color - Black; Lockable (y/n) - No; Material - Steel/Aluminum;
Number of Compartments - 1; Product Height 6 in; Product Length 6 in.; Product Width 11 in.
Shipping Weight 6.15 lb.; Number of Drawers 2; Working Load 10 lb.
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
Nice toolbox, setup.
However, I am interested in an “in the bed” tool box. I have a small floor Jack, a 12 Vdc impact wrench, torque wrench, 12 Vdc air compressor, tow straps, and few other small items. A small bix of 12x12x30-34 long will work. I was hoping .Mrs Santa would put one under the tree, but nope. Birthday on 17th.
LBCOX
Larry
NM
2024 Mav Hybrid
Went to HF...think I can get more tools under the seat without all the metal casing...no go for me.
