Tire rotation pattern
What vehicle requires 4 unique tires?
A Corvette and many other musclecars/sportscars comes with different spec front and rear tires. And then if those tires are directional, they can't even be rotated left to right without dismounting and remounting all four tires.
You caught me in a slight exaggeration :) , but in reality, you still don't rotate them.
____
Also, Scotty Kilmer is a hack, and any time you see any reference to him or god forbid a link to his YT channel, the only acceptable response is 🤨 and then keep scrolling.
trumpet77
2023 Maverick XLT, 2009 Porsche Cayman
I'd agree that you should still rotate, a typical front or rear wheel drive car will show more wear on the drive tires, even my 2011 Camry did.
Johnkn
MD
____
Even if different size front to back, unless unidirectional, they should be rotated...
commadorebob
Last time I had tires rotated on a vehicle, dealer did the traditional pattern.
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
Even if different sizes? You cannot rotate staggered fitment tires. You can move them left to right, and on sports cars that will help even out inside wear. But that is still not as effective as cars that can be rotated front to rear.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
To be honest our vehicles are not perfect... :eek:
If you think on the forces being put on a tire, every position (right front, left rear, etc...) is different. Yes it may be minute, but it is there.. 🤔
On Scotty boy, he can't makeup his mind. First he is glorifing something and next week, he's roasting it... :(
Jerry
Johnkn
MD
I didn't suggest doing a 4-tire rotation with different size tires. What I said was that even if the tires were different sizes front to back they should be rotated (as the previous poster stated that they should not).
"Hopefully' everyone here is bright enough to understand that you wouldn't do a full 4-tire rotation with different size tires, but in that case they would be swapped side to side, but in the Maverick Forum you never know.. ;) (y)
take care
NJBob
NJBob
New Jersey
Well if you have a Mr2 like I do with directional rotation and different sizes front to back. It is.
Shay
Sam
Phoenix, AZ
www.youtube.com
2022 Ford Maverick XL Hybrid (sold)
No,check out Scotty kilmers podcasts.rotating was necessary for bia ply tires.not so much modern radials. Like I said I haven't rotated a tire in prolly 30 years and haven't noticed a need to.
Without saying what I think about Mr. Kilmer and the ideas he puts out there I can say that rotating tires is a must if you want to replace all four at the same time, with the same amount of wear.
This is especially true with a front-wheel drive based vehicle that always wears down the front tires faster than the rears because they handle steering, braking and power traction. The rears are just rolling along.
I rotated my original Continentals on the Maverick at about 15k miles when I saw a significant deal more wear on the fronts. By the time I replaced them all at 30k miles, they were all evenly spent.
Moby
Fort Erie
Hummer H3 sprinter van 65 chevy 11 Doka syncro
Keep in mind when you rotate your tires ,you need to reprogram your tire pressure sensors. I just had the new wheels and tires done today . Tire guy just goes from tire to tire with a box thing and the horn blows .
NJBob
NJBob
New Jersey
The Mav is supposed to do that automatically. From what I know.
ejouie
Evan
Newnan, GA
'23 Ford Maverick, Atlas Blue, FWD, EcoBoost, XLT
The manual is correct for all stock tires that the maverick has come with so far. Deviate from stock design, expect to need to deviate from the manual as well.
Also, vehicles that cannot have their tires rotated aren't super high end. the Grand Prix GXP had wider wheels up front. If you were to put Cross Climate 2s on that, you wouldn't be able to rotate them at all.
LSchicago
Lloyd
IL
Swap diagonally unless they are directional then just front to back on the same side. If your rears are bigger than the fronts, they don't get rotated.
LSchicago
Lloyd
IL
Cross climate 2's would just be swapped back to front on the same sides.
ejouie
Evan
Newnan, GA
The wider wheels would only fit the front. (W Body with the LS4)
