Just mentioning you want a certain offeset doesn’t mean much if the wheel widths change. A +45 offset wheel will fit the same as a 38-39 if the wheel is .5 inches wider.Yeah, I went through the whole list (with filters relevant to my needs) and was frankly disappointed. Keeping to 38 or 40 mm offset eliminates a LOT of wheels. I don't think I want to go to 45.
Was going to mention the same. If you went with a 8 inch width that was a +45 off set would it not stick out farther than the stock set up ?. The 225/65 R17 can fit on a 8 inch width. Is there a downside to going that route?Just mentioning you want a certain offeset doesn’t mean much if the wheel widths change. A +45 offset wheel will fit the same as a 38-39 if the wheel is .5 inches wider.
Correct. It’ll stick out about 5mm more. In most car/trucks theres playroom cause the wheels are always so sunk in. But in the Mav wheels are already flush. I believe Ford said early on they did so to make it look wider then it is.Was going to mention the same. If you went with a 8 inch width that was a +45 off set would it not stick out farther than the stock set up ?. The 225/65 R17 can fit on a 8 inch width. Is there a downside to going that route?
Yeah. Thanks both for reminding me. I have a set of 17x8s w/45mm offset in my shopping cart right now.Was going to mention the same. If you went with a 8 inch width that was a +45 off set would it not stick out farther than the stock set up ?. The 225/65 R17 can fit on a 8 inch width. Is there a downside to going that route?
Let the discount tire place know you want them if they trade for some or maybe nearby stores get them they will get them for you more so if you buy new tires from them.Thanks for the heads up, OP.
No matter how many wheels I look at, I keep coming back to the same two options for my Cactus Grey Lariat:
Alphaequipt Foxtrots in all black or FX4 package takeoffs.
I have a feeling the latter will be relatively tough to come by so I may end up with the former.
Yes, the Focal F20 in 16". I did an online chat with an agent and pointed out to him that the TR system shows they fit he said essentially "mistakes happen". What TR will do if the error is because of their system is send call tags to have the bad set returned at their expense.Not sure how accurate the site is, they have wheels with almost an inch more backspacing they say will fit and they have 16" wheels listed which another thread said hits the brakes.
I can only say that I've been buying from TR since 1984. I did a radical +2 on a very low production car with their assurance that they'd done a test fit. It worked.Not sure how accurate the site is, they have wheels with almost an inch more backspacing they say will fit and they have 16" wheels listed which another thread said hits the brakes.
