service vehicle soon light code P0C4A
acelee1895
Adam
2023 Ford Maverick Hybrid Lariat, 2015 Ford Fusion
2023 Hybrid Mav with 8500 miles. The service light showed up with no notifications on the ford app, dealership said probably oil change due to miles. It disappeared before I could get it scanned. Then came back later the same day and had the ford app notification this time. When I got it scanned, came up with that code. Dealership is now closed so I can't get any information from them. Seems like a big problem because it has to do with battery cooling but there's no other lights or warnings. No effects to driving abilities. Do I stop driving it till I can get it serviced or let it slide being that it goes off and on?
Ford Maverick service vehicle soon light code P0C4A IMG_2215
Local auto parts store should be able to scan and see codes thrown, might give a better idea deciding to drive or not
acelee1895
acelee1895
Adam
I already got it scanned and have the code in the title as well as the picture of the scanner with the code in the post. It is P0C4A. Hybrid battery coolant pump control. Looking online doesn't show anything for the Maverick but does show some stuff for the Volt. There is coolant in the overflow between the high and low and it is warm but not hot so it is flowing.
Hum maybe related to the heat exchanger issue. Search that term and maybe see if any similarities. just a guess
acelee1895
acelee1895
Adam
I am not familiar with the heat exchanger issue, do you by chance have a quick link to that?
Their will be numerous threads/ post, click on the magnifying glass top right of forum screen type that term in and search. It’s what controls the heat/cooling of battery, may or not be related to your issue
Montana
Had the same issue on a Hybrid Escape. They have a TSB for it somewhere, easy fix.
It usually happens on colder days, but can be solved by simply rolling forward then back, shutting everything off then back on. It usually fixes itself. It's just a miscommunication. Call your dealer and it should be fixed under warranty. Not sure if there is a recall on the Mavs for it (yet), but there was for the Escapes.
Not related.
acelee1895
acelee1895
Adam
Make sure both chambers of the reservoir are full. There was one member who had a leak in the HV cooling side of the radiator that had a similar code.
Both chambers are within acceptable level and the one closer to the firewall is the less hot one for the electrical system. Thank you for the idea
acelee1895
acelee1895
Adam
acelee1895
acelee1895
Adam
Not related.
Easy fix as an software update? I really don't want to get into the waiting for parts at the shop for weeks like others are reporting.
That's what I am thinking since its not triggering any overheating lights on anything else. Definitely not colder days for me though, Florida and high of 85. The light hasn't been on today the couple short trips I have taken.
acelee1895
acelee1895
Adam
searched power train malfunction reduced power, noticed this
https://www.mavericktruckclub.com/f...nction-reduced-power-issue.30571/#post-564112
When your dealership opens, call, they should be able to see the code with your vin info and give advice
That's what I plan on doing. I just realized they were open today and I should have called but I assumed they would be closed all weekend. Something, something, making an a-- out of myself. I appreciate all your inputs
