Smooth_criminal
Smooth_criminal
Michael
Johnson city
1966 ford f100, 2022 Ford Maverick ecoboost
What torque specs you want i will post them here tomorrow when i go to work .
Front: strut upper and lower mounts, sway bar end link, tie rod ends.
Rear: shock upper and lower, control arm bolts.
That should be everything important.
Smooth_criminal
Smooth_criminal
Michael
Johnson city
Finished mine up. My overall drop was 3.25 inches front and 4.25 rear after driving about 10 miles around the neighborhood. All fenders measure 30 inches from ground through middle of hub. Front rebound set to 12/24, rear 9/24 (lower=softer). Ride is actually pretty good, about the same as the Jeep renegade trailhawk I had before or most 4wd suv's I've driven. On harsh bumps and bridge transitions the rear has a slight bounce. Will probably adjust rear dampening to see if it changes. Pictures of before and after.
AWD Scale coilovers, standard version, full drop.
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220922_120352
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220922_120417
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220922_120405
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220923_114938
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220923_115022
Ford Maverick Scale Suspension Coilovers for 2022+ Ford Maverick [installed photos added] 20220923_115012
volksnuts
Katy,TX
Maverick Lariat HPR
Well that’s annoying….standard drop looks like the low
Looking good though!
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Looks lower than mine sorry was busy today at work . What height you adjusted to
Smooth_criminal
Smooth_criminal
Michael
Johnson city
The coilovers are as low as they can go unless removing the lock ring on the rear. That could get another 3/8 inch or so. To preload the rear I used a jack to compress the spring 5mm then adjusted the shock length until it bolted up. That's how I understand the instructions and was similar to the ridetech set I have on my f100.
Vtec87pr1
Antonio
Virginia
youtube.com
Ok i still got more to low
Smooth_criminal
Smooth_criminal
Michael
Johnson city
Vtec87pr1
Antonio
Virginia
youtube.com
How’s the ride?
Did you get the low option or standard?
I got the low option so i still have more to adjust . Rear its bouncy im thinking i put too much pre load on the spring and i still havent adjust the dampers so that might help but the front its good and supposedly today my rear cambers arm should come.
volksnuts
Katy,TX
Maverick Lariat HPR
I’m going to mess with my suspension today
It’s been 2000 miles so I’m just going to make sure everything is still good
Will check the damper adjustments because I never messed with them and it’s good that we now have two mentions of a decent ride out of these
Vtec87pr1
Antonio
Virginia
youtube.com
I juts put them so im going to driving them today and tomorrow will see. An play a little bit on the week might go lower
