Roof Load Limit
FortyFiveNorthoods
PNW
2022 Ford Maverick Lariat FX4 4K
For those interested in adding a roof rack. Have we seen anything confirmation of load limits for the roof with or without the moonroof?
Scooter66
Scott
Saint Augustine
2016 Ford F-150 Lariat
Ford Escape is 100 Lbs. from what I seen. I was hoping that a Rhino Backbone system could fit on the Maverick but too early to tell.
MarkG
Dallas TX
Subaru Forester
It would be limited by the weight limit specified by the manufacture of the cross bars. The roof of a vehicle will support a lot of weight at the edges which is where the roof rack typically mounts.
RicksMav
Richard
Bellingham WA
2011 Ford Transit Connect
I too am interested in this. Will be using this as a work vehicle.
mcarneybsa
Albuquerque, NM
Honda Element
Does anyone know/can confirm there are actual mounting points on the roof for a rack? My dealer couldn't confirm that for me, and I am not very keen on running a clamp-on style rack between the roof and the doors as they absolutely wreck the weather sealing. I'm hoping to pair a roof rack with a bed rack to be able to stably carry longer SUPs, kayaks, canoes.
HarrisonFordMaverick
Arizona
Subaru Outback
This is true but that weight supporting ability is while static. The ratings are always different for dynamic which usually 100-200 lbs, and off-road is even less at usually half of the dynamic rating.
Arizona
Subaru Outback
I would not mount a Rhino Backbone. They are usually held on by pop rivets which is barely enough to hold on the rack itself. There are several YouTube videos from the aussies of them failing.
Arizona
Subaru Outback
I’d suggest reaching out to Spider No-Drill and see if he’ll be making one. The owner is an aerospace engineer that can make roof racks that do not require drilling into the roof or clamping around the roof and ruining your seals.
ToyotaTurncoat
New Jersey
2014 Toyota Tacoma Double Cab TRD Off-Road
For what it's worth, I've been running Thule roof racks on my Tacoma for over three years and have no damage to the seals. Maybe they interface with various cars/truck models differently, but I haven't had a problem.
mcarneybsa
Albuquerque, NM
Honda Element
I did reach out to them. They said I could bring it by their shop for a custom build 😂
mcarneybsa
Albuquerque, NM
Honda Element
Good to know. We have a cheap Sport Rack from eTrailer on my wife's civic and you can see where it's stressing the seals quite a bit. So far no leakage I'm aware of, but we live in the desert, so not a lot of water to test it with.
Connor
2019 Ford Ranger
Did anyone ever figure this out or maybe in another thread? Just very curious about the specs. I have a 2023 XLT on order and plan to use this for work and I will be putting a roof rack in combo with a bed rack to haul medium/light loads of long lumber/trim material. So just curious about the actual Maverick roof weight capacity vs what the installed rack itself can handle.
Gregor
Portland Oregon
05 subaru outback 2.5i, 93 Ford ranger XLT LB
🤯 how does he do it?? Gecko feet? Spider toes?? Seriously need to know more!
Gregor
Portland Oregon
Yakima roof racks state 600lbs static load and 165lbs dynamic. Thats not a lot of lumber😕 maybe bed mounted racks can handle more dynamic load? They must.
