date done 7/14/22
done at Oroville Ford
Dropped off 11am picked up 3pm.
Comment: They took me home and picked me up when done.
First class dealer no dents/scratches or grease left on truck. Always look before leaving.
Work order only says drill 5 holes and remove 4 blinds
I am not sure the square holes were already there as I did not take before or after pictures. Below picture shows the 3 round holes in front part of under engine shield. Material is soft and fuzzy kind of but rigid.
Picture below shows the 2 rear round holes by the large square hole which not sure it was done today or was there already.
This one shows the center support behind the grill where the shutters are visible. It is a little tricky to see but look for one missing as you will see the center hole and a pivot hole left in the center section where the shutter was inserted like the ones still there. The lowest shutters (below the lincense plate) and the lowest shutters above the license plate were removed.
