Rear LED light bar recommendations?
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
It came with a transfer box that does something to bypass that problem of the guidelines on rearview cam going away, they stay. I just ran power cable to batt.,and pull rear taillight out to tap into reverse light wire. I have a 23 and even though this lightbar would fit under tailgate, it would have blocked access to spare. I also screw alum. angle into 6 existing screws, pulled them out and reused same screw
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Does anyone have any recommendations for a rear LED light bar? You know the kind, they plug into your trailer wiring and provide brake reverse and turn signals?
Surely , someone has found one that works on their new Maverick?
https://www.amazon.com/dp/B084Q54XWP?ref=ppx_pop_mob_ap_share
This one works and does not effect the guidelines in your rearview camera. Had to mount under bumper ,otherwise it covers spare tire hole. 1 1/2" x1 1/2" alum angle.
Ford Maverick Rear LED light bar recommendations? 20230311_152409
CTYankee
Central MA
2022 Maverick XLT
On the MY22's (and presumably, the MY23's), there is a vertical lip on the bumper just below the tailgate. We mounted mine there, which got it low enough to be seen properly and, on a regular light bar, would avoid any conflict with the spare tire access. Since mine is a split Putco blade, someone would have to measure that lip to ensure it would take a 48" single bar.
CTYankee
Central MA
2022 Maverick XLT
The first picture is a close-up of the bumper flange with the split bar mounted. Anything higher will not be directly visible (even standing 20-30 feet away), which reduces the usefulness of the bar. A full bar would cover the spare tire access, which I had thought was higher up until I took this picture.
The second picture shows the full bar. Each section in this case is 18", so you still get 36" of extra and very bright lighting.
Mine is installed with a Curt T-harness that is Maverick specific and saves having to splice into the factory taillight harness.
Ford Maverick Rear LED light bar recommendations? Bumper Flang
Ford Maverick Rear LED light bar recommendations? Split Putco
BoricuaBeautyx
Tatiana
Madison, AL
2023 Ford Maverick XLT
I just got out of H&H after 3 hours of them installing a Putco blade. It worked fine, but whenever I attempted to use the remote start, the left tail light didn't turn on. They hard-wired the blade directly to the lights wiring. Had to take it off because the left tail light would not turn on during remote start. Do you think adding this harness would've fixed the problem?
CTYankee
Central MA
2022 Maverick XLT
I believe the Curt harness would have prevented that problem. I also think they wired something wrong and need to correct it.
notfast
Los Angeles CA
When I first saw this thread I was hoping that someone got the OEM roof spoiler and attached a chase bar to it.
https://accessories.ford.com/products/satin-black-rear-cab-spoiler
https://www.amazon.com/dp/B074NVHHBN/
When I had my F-250, I installed a Back Rack and some 6" oval LED stop/tail/turn lights. I was told that it was a great improvement to being visible from the rear as well as letting traffic far behind know I was braking or signaling since those lights were high above the other vehicles.
BoricuaBeautyx
Tatiana
Madison, AL
Do you mind linking me the harness? Thank you for your response!
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
49" LED Tailgate Light Bar + Signal Box [Ford F-150 F-250 F-350 Super-Duty up to 2018] [Sequential Turn Signal] [Tail & Reverse Light] for Ford Pick-Up Trucks with Tow Package & BLIS.
This plugs right into the trailer plug and does notmake the guidelines in the rearview cam disappear. I had to mount below my bumper on a 1 1/2" alum.angle bar . Will not fit properly under tailgate
Dad
'In all honesty, I've yet to see a rear light bar that looked good and/or made the vehicle that much more visible for turning or braking. I think Ford did good by making the Maverick's tail lights oversized (for the size of the truck). If you want more visibility then I would suggest replacing the standard incandescent bulbs with LED's and don't forget the one on over the cab.
Doburden
Krassimir
I bought a very cheap LED light strip and tapped into the taillights. Plugging it into the 4 pin hitch disabled some of the cp360 functions.
Which wire numbers from 6 pin tail light connector you used for 12v red and ground black?
Thank you
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Post above , best for me plug and play ,nice and bright
  • Like
Reactions: Dad
