Private offer???
Sin.D
Cindy
Got7Got7@24
Finally my23 is on it's way and will be here Feb. 03, 2023. It's been a long way since the first order on 10.23.21.
I was in contact with my dealer throughout the whole process. Each time they assured me that it's okay and that the order number from the 2nd order in September 2022 does not need to be the same as the first order in October 2021. Now, the issue is that they are not able to find the transition private offer for me. I even called Ford customer service, and one of the rep told me that the order number must be the same in order number.
I contacted my dealership, and they cannot find anything in their system under my name and said the I should have received an email from a 3rd party vendor regarding the private offer.
Since November, when I received my email that my23 was going to be built, I have made many calls to both Ford and my dealership. I am at the end of my wits, and honestly, I am exhausted. Can anyone help?
barxlt
Bart
Lavallette NJ
2023 Maverick Cactus Grey
Never herd of a 3rd party email for the private offer . Ford customer service had my certificate number for which I used it to pick up my XLT Friday with know troubles .
mktmgrjrm
North Central Ohio
2025 Maverick Hybrid, 2024 Escape Hybrid
If FORD has no record of your Private Offer and your dealer has no record of your Private Offer, the dealer will need to contact their FORD inventory specialist person. According to @fordvideoguy the dealer should be able to sort this out with the inventory specialist to get the old and new orders tied together to get your Private Offer.
EDIT: Agree with barxlt - the Private Offer is not handled by a 3rd party.
Sin.D
Cindy
Got7Got7@24
Thanks
Sin.D
Cindy
Got7Got7@24
Dealer said I should have a certificate number.
Should I have one and wherr can I obtain one?
@fordvideoguy help?
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
@fordvideoguy help?
Do you know if your dealer properly obtained COVP approval for your 22 Maverick? The private offer is dependent on that.
Sounds like they are just trying to make you search around elsewhere in vain. Dealers can easily obtain your certificate number (if one exists) by searching your name and address in SmartVincent.
  • Like
Reactions: Aza
mktmgrjrm
North Central Ohio
@fordvideoguy help?
If you had a MY22 order that was COVP'd and your dealer or FORD created a MY23 order (depending on whether you had an unscheduled/cancelled order or scheduled/cancelled order with VIN #), you should have a private offer. FORD required the MY22 order to be COVP'd to qualify. If you've contacted both FORD and the dealer and they cannot find your certificate your dealer is going to have to work with their FORD inventory specialist to sort it out.
Shakesbear
J. R.
Lots of info on this on this forum (myself included ;)). Check this one out:
https://www.mavericktruckclub.com/forum/threads/rollover-discount.26484/
Grand Nat.
NYC/ L.I
Schwinn Stingray
This might have something to due with your dealer not applying the proper procedure. Just a guess on my part. As soon as I read you complaint I called Ford customer service number to see if my private offer still applied to my order. I did change my trim to a Tremor in January after waiting a year and it was scheduled the next week. I was also told that I might not now receive the private offer through all sorts of info sites. However the Ford rep. informed me that the offer is applied to my order and gave me a certificate # and a program # to forward to the dealer. And an estimated delivery date. Did you get a VIN # yet? If you did not the info my not be available. Did you do a COVP with you dealer when you put your order in? Don't give up hope you might be able to clear this up.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Of course you received a Vin# you said your vehicle is on its way. I need glasses.
Skeeter163
Don
Hertford NC
2017 Escape
My dealer says there is no longer n inventory specialist.
Timothyd
My Maverick is in production and the dealer can't get the private offer to show on the invoice. I told him to check all the data to see if it matches, says yes. (I hope he checked good) Well, he's got 3 weeks to work it out. Or I'll be pissed. This entire Maverick episode has been a lot of messing around for 15 months now.
skadizzle
Orlando, Florida
2023 Ford Maverick Lariat BAP
The Ford rep told me the same thing about third party and I believe that's true. They probably sent out the 7000 VINs to someone to generate the certificates for them.
I had this same issue on my canceled order. They couldn't find it in the system. It turned out they had my address wrong and had my house number but the dealers city and zip. I was told the dealer can find the certificate I'm smart Vincent using the name and ZIP so maybe try a different zip code and see if they did that by mistake.
