- Jul 6, 2021
- Covington LA
- 2018 F150 Scab 2.7EB, 2017 CR-V
^This. It's easy to both under-think and over-think payload/towing/etc. The info we need is out there, just not always easy to find in a single place. A good non-Ford primer on this is What is Payload: A Complete Guide | Kelley Blue Book (kbb.com) .No, payload is the total amount of weight the vehicle can carry. Passengers, cargo, everything.
No, payload limits do not change if you're towing. But keep in mind that a trailer's tongue weight is subtracted from the tow vehicle's payload capacity.
Absolutely. Say the bike plus trailer is 1000lbs. Typically you want 10-15% tongue weight, so we'll just draw it at 12% or 120lbs. If you had the hybrid pictured above, that'd leave you with (1519-120) 1399lbs of payload left for yourself, your luggage, your gear in the bed, etc.
Payload is usually the lowest-common denominator when towing, and the reason why people have to step up to a larger tow vehicle. They simply run out of payload capacity before anything else such as GVWR, GCVWR, RAWR, etc.
When I see F-150s towing a 30' RV trailer and they have everything plus the kitchen sink in the bed and they have a cab full of passengers...I try to pass them as expeditiously as possible.
Typical F-150s crew cab 4x4s have a payload of 1,500lbs (convenient, huh?). Five 150lb people is 750lbs. If your 30' camper grosses at 7000lbs, that's 700lbs of tongue weight. Leaves you 50lbs for stuff in the bed.
1. When the Maverick leaves the factory (with a certain powertrain and trim level configuration, with options listed as per the window sticker), that yellow payload sticker reflects it's actual payload capacity with a full tank of gas. Remember the basics - GVWR minus Base Curb Weight (and base curb weight includes a tank of gas) = actual Payload Capacity (that yellow sticker). If you don't believe that, check out Ford's 2021 RV and Towing Guide.
2. Actual payload capacity (yellow sticker) does not already include a 150 lb (or whatever weight) driver. What does the sticker say - "the combined weight of occupants and cargo should never exceed xxxx lbs". A driver is an occupant.
3. Think of if you did a free-body diagram of "post-factory loads" applied to the Maverick. Your starting point would be as it was when it left the factory. That spray-in liner you got as part of the XLT Lux package, and the floormats, and whatever else you see on the window sticker? Those weights are already "baked into" the yellow sticker number. Now you put an aftermarket roof rack and tonneau and (whatever) on the truck. You have to subtract their weight from the yellow sticker number. Now you people in the truck - got to subtract their weight from yellow sticker. "Stuff" in the bed, trailer tongue weight applied to that hitch ball - subtract from yellow sticker. You keep doing this until all loads are accounted for.
4. There is "pulling", and there is "towing". Imagine if you wanted to "pull" a really loaded (8000 lb) haywagon and you had a pintle-style hitch on your Hybrid Maverick. You could certainly do that (an external rolling start probably needed...) even though the Hybrid is only rated for 2000 lbs max. loaded trailer weight. Remember the Tundra commercial from a few years ago when it "pulled" (not towed) the space shuttle? Same thing. "Towing" is different.
5. 1400-1500 lbs of actual payload capacity is pretty dang good for the Maverick. Like notfast said, I know of many late model upper trim level F150's that have yellow sticker payloads less than 1400 lbs. When doing your sums for "can I tow this?", 9 times out of ten it's payload that gets you.
