Chris McD
Norwalk, CA
2022 Ford Maverick XLT
Awesome! Are you getting a full wheel turn with no rubbing at that size? I'll probably put all terrains on either when I get my hybrid or when the stock tires wear out.
Jmsmith91
Jmsmith91
Grand Prairie, Texas
2022 Ford Maverick XLT FX4
No rubbing at all, including when I was off road.
jcsan18
JC
NC
Those tires look great on your Mav.
‘80F100
Jonathan
1980 F100, 1996 Ram 2500, 2001 Ranger, 2014 Edge
Post a pic of deer blood in your truck bed and we'll say it happened at the same time 😉
I haven’t gotten a buck yet 😔 I’ve just been seeing little guys. But when I do I’ll make sure to post it.
2022EOW
Marty
Missouri
2014 Focus
Hmmm this has me wanting to throw some A/T tires on my hybrid when it gets in just for the looks
Why buy a hybrid FWD and slap A/T tires on it that will also reduce your gas mileage. Buy an EcoBoost.
Chris McD
Norwalk, CA
You still get the advantage of better traction. And if they're snow rated then that's also an advantage.
XLTLUXRED
JM
Vermont
Maverick hybrid, Mini 4 door
So, help me out on the tire size. Awhile back I looked up what snow tires to get for our Maverick (when we finally get it), and read 225/65/17. Will those work or was that info incorrect?
L_Ron_Hoover
Cleveland
Lariat; hybrid; luxury, locked vault up front
Forgive me, I can't wait for my hybrid but I'm not a big car guy: why do those tires decrease gas mileage? I assume they require more energy to propel, but not sure why. Is it the tread?
notfast
Los Angeles CA
The tires are BFGoodrich KO2 245/65 r17 with white lettering. They're slightly bigger than stock but by only about .75 of an inch overall diameter.
From a looks perspective, I think the KO2s have the coolest/most aggressive looking sidewall design. I'd be torn between the KO2s or the Toyo AT3's.
I had KO1s on my F-150 and they were the best sand tires I've used. However, they freakin' sucked in the rain. I'd rather drive on highway tires with 2/32 tread than fresh KO1s.
I'm talking like, I'd spin the tires while barely rolling onto the gas from a stop, occasionally drive doors-first around circular on-ramps, and occasionally slide to a stop. Hopefully the KO2s will serve you better.
People have different wants/needs/desires. Let 'em spend their money as they see fit.
I'd do the exact same thing if I had a hybrid. Slap on a decent set of A/Ts for function as well as for looks. In my opinion, tires are the best bang-for-the-buck item you can purchase to improve what is important to you for a vehicle. Want better gas mileage? Get LRR tires. Want better off-road performance? Get A/T tires.
I used to live out in the country. The road to my house was a mile of gravel and crushed rock. Highway tires would get death by a thousand cuts, so I ran A/Ts on my 2WD trucks.
Aggressive tires like all-terrains or mud-terrains are typically more robustly constructed, are heavier in weight, have deeper tread, and/or have more rolling resistance, which all contribute to an increase in NVH (noise, vibration, harshness) and a decrease in fuel economy. To what extent is dependent on a lot of factors.
When I went from the LRR (low-rolling resistance) highway tires to aggressive A/Ts (or mild M/Ts, depending on your perspective) on my Nissan Frontier, I lost about 10% of the fuel economy. The tires also hum noticeably to the point that it sounds like I have four bad wheel bearings.
But it's all a tradeoff. I popped two tires while off-roading, so the hum and fuel economy hits are well worth it to not spend $120 per off road trip to replace a tire that pops or gets ripped open. I don't consider myself an aggressive off-road driver either. I got a 1/2" hole in one tire when I spun a tire on a gravel hill. I ripped another tire open when I spun a tire on a rock and the truck slid sideways a few inches into basically a natural curb with a sharp rock that ripped the sidewall open.
The new off-road tires grip gravel and rock much better than the LRR highway tires, so I don't spin the tires much at all anymore. And even if I do, the new tires have deeper tread blocks and aggressive side-biters (basically tread on the sidewalls) that'll rub on rocks and reduce or prevent damage to the sidewalls themselves.
CLH917
Travis
Madisonville, LA
Bigger = heavier and more rolling resistance.
