I really appreciate your in depth write up, it's getting me over the fear of tearing into a brand new truck. CheersI mounted the Rockville sub today on the Maverick's B&O mounts. It took quite a while because there seems to be no rhyme or reason for the hole placement on the B&O mount and nothing aligned. Maybe that's just the way B&O designed their sub and Ford made the mount to fit. It took careful measurement to determine hole location and layout them out to drill in the HDPE. After drilling the holes, countersink and determining they will match up to the B&O subwoofer mount, I painted it flat black. After it dried, I mounted the HDPE board and the sub. In the next day or so, after installing the 6.5" front speakers, I'll run the #8 AWG power cable, ground cable, RCA cables, remote wiring, and the sensing power wire. I'll also have to cut some of the mounting screws length off and install some Kilmat on the rear cab wall.
I learned today that the DSP Amp is three weeks to a month out. I'll be glad when it arrives and I can get it installed. I guess that gives me time to further research the ACM rear speakers bass output to see if Forscan can be used to remove any limitation. We'll see.
More later.
