Motorcraft FL910S Cut Open, Used Motorcraft Oil Filter Cut Open 1-9-24
Decayed
Decayed
yes
a car
Zzzzzzzzzzzzzzzzzzzzzzzzzzzz%zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Yet here you are, posting in the thread! 🤣
OleFordGuy
Well wasted 9 minutes of my life on that video
MaverickSVT
Ohio
2000 Ford Contour SVT
Why is the little extra glue an issue?
I bet that filter is so clean because it was less than 5k miles and it was a hybrid.
The gas engine was not running the entire time.
Would be interesting to see one cut open with same miles on the filter from a EB.
damnclose
Jeff
Greenwood, IN
2016 Dodge Caravan, 2002 Chevy Silverado 4X4
This youtuber cuts open oil filters. This one was used in a maverick.
Thanks for showing this video. I am glad to see this filter is built pretty solid. I will continue to use motor craft FL-910s on my Hybrid maverick. Nice to see how well it is made, much better than most.
Decayed
Decayed
yes
a car
Yeah he's done other motorcraft filters in the past and it convinced my that they are a bargain. They have all the necessary features and the build quality is good. If you are changing your own oil there is no reason to buy anything else if you own a ford. Unless it's really old and you don't care in which case walmart supertech filters are just fine - another brand he's cut open and shown good build quality inside.
Decayed
Decayed
yes
a car
I think it's indicative of a potential issue if the excess glue should come loose and get into the engine. Shouldn't happen. But it's probably not an issue and could well be a manufacturing one-off.
FWDMav
Frans
Westerville, OH
2023 Maverick XLT, 2021 EDGE, 2014 Fiesta ST
Wow they are $8.44 now. I stocked up on a half dozen FL910S for my Fiesta ST and I think the price was half that pre pandemic at Walmart.
Decayed
Decayed
yes
a car
you can get them for $6.25 each on amazon if you buy a dozen.
inflation is a harsh mistress.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Thanks for posting that link. I have kept the tiny factory filter with plans to open it up. My favorite part was his filter case cutter. Think I will have to build one of those...
James K
NY
Thanks for video. I too will build one of those cutters. I used to run the last of the oil drain through cheese cloth to see what was going on. Your cutter is a better way to go.
Decayed
Decayed
yes
a car
For the record, it's not my video. I ran across the channel when I was researching filters and liked his direct approach to evaluating them. While it's not always clear exactly what kind of filter media is used, you can certainly see the features and build quality of the rest of the unit.
stevj
Stev
usa
2024 Hybrid Maverick
That's one tiny oil filter.
