ImGoose
Houston, TX
Kia SUV
Tossing this out there to see if other maverick owners are in the same boat. Does your tailgate angle downward ? Not level with the bed floor ?
Yep, mine is the same way.
Criss944
Criss
Horry County, SC
Silverodo
With the door bounce when closing might be showing how airtight the cab is
Air pressure shouldn't make closing the door difficult. There is a vent behind the back seat to let air out.
dalola
Ohio
F150
Years ago I had a car with very tight seals, and when I opened the car door, it would automatically roll the driver's side window down just a little. The door would close easily without the air pressure inside. If you park your Mav inside a garage, maybe a temporary solution would be to park it with the driver's window down just a smidge until the seals get broken in....
That is typically a design feature of sashless doors, as there is no upper support for the door glass when you open & close the door.
TCK
Jetta Sportwagen
Have seen it in many videos of the bed- I believe it was designed this way, it certain why
Bmckenz
Brendan
ON, Canada
2022 Maverick Lariat 2.0 AWD
I’ll get pictures later, seems to pull down the straps on the bed extender way more than you would expect. I’ll check with the dealer but something seems off
TheRodster14
Rod
Dillsburg, Pa
I’ve driven my Maverick 1k miles. Here’s my review!
CONS
1. The radio antenna has some sort of problem. AM and FM stations have far more static and cut out than any other car I’ve owned.
2. Not Maverick-specific, but I hate auto-start-stop. I wish I could completely turn it off. There’s a button to do so, and also the option in settings. Option in settings should turn it off completely.
3. Middle seat buckle notification — I wish this also lit up green when the middle seat passenger has buckled their seatbelt.
4. For some reason my doors need to be closed pretty hard, as least in comparison to my Tundra.
I do not have the hood bounce issue.
PROS
1. I love how it handles.
2. I love the smooth ride.
3. Plenty of storage for my purposes.
4. My small kids (11, 8, 4) can easily fit in backseat with boosters.
5. Gas mileage is a huge plus. It’s performed mileage wise exactly as I suspected.
6. Seats are very comfortable, even at 5’8 and pushing 290lbs.
7. It towed my utility trailer with no problem. I do not have the 4k tow package.
8. It looks great and i get comments every time I stop somewhere.
I got mine off dealer stock a few weeks ago. I paid MSRP.
Here are some pictures, including last night where it served as transport for 5 kids, my wife, and my friend as we went trick or treating.
She's a beauty! I did notice in mine the first couple of days about the door-shutting. It just seemed to need a little breaking in.
ImGoose
Houston, TX
Kia SUV
I am starting to think it has something to do with the two level option.
They needed it to be at the same height as the wheel wells when using the other attachment point. That length and the length to have the tail gate level when fully down aren't perfect.
The outcome it the slightly off-level tail gate.
Stupak
Stuart
Los Cabos
2022 Maverick FX4
CONS
PROS
Hi. I have an XLT in cactus grey with an FX4 package. I take possession in two weeks; it's already at the dealer :) Question-I also dislike auto start/stop. I thought you could legit turn it off?? Are you saying if you use the turn-off option, it doesn't stop the behavior? It will be unfortunate, mainly because I checked before the purchase. Thanks in advance
mcm2839
Curtis
Houston
Toyota Tundra
It doesn't stop it forever, you can only turn it off for that particular driving session. Once you turn it off, it'll revert back.
Deacon Blues
Ron
British Columbia
2017 Honda Fit, 1997 F150
I hated the auto stop-start on my BMW X1, but luckily I was able to turn it completely off.
I'm hoping there will be some way to do the same on my new Maverick.
Bmckenz
Brendan
ON, Canada
I tipped up the tailgate the halfway position. Still seems to be angled down slightly from level with the wheel wells. This position seems to be more forgiving with the geometry of the cables on the tailgate. I feel like they could afford to be shortened a fair bit and not be an issue in the halfway position. I will have my dealer look at it.
Jbuys
Washington State
96 Mazda 626, 05 Ford Escape 22 Maverick
CONS
PROS
You complain about your AM and FM radio reception. Try putting the rest of the antenna on it, I noticed it only has the shark fin, it should also have a short straight antenna that will screw into the shark fin, you should get better reception with that in.
mcm2839
Curtis
Houston
Toyota Tundra
Yea, thanks to you and the person above, I had no clue it was missing part of the antenna. They didn't put it on before I drove it off the lot and I can't locate it in the truck. The dealership ordered one for me, so it should be fixed here soon!
Hagzfilmz
TH
Sacramento
(Ordered) 2022 Ford Maverick XLT 2.5 Cactus-G Lux
Yes! I got rid of my 19' Outback before I got a Maverick and my spouse has a Mazda3. You could close those doors with you breath. I find myself having to slam the door or else it bounces back partially open. This could be attributed to the number of seals. That only helps to reduce noise so it's worth the tradeoff.
I noticed that on a test drive. I believe It could be due to such a solid air tight seal in the cab which is reason so little road noise. I opened the window and tried again for comparison and door seemed to close with much less effort. This is a good thing all the way around in my opinion
Ih8thew82
NE Ohio
2022 XLT LUX Hybrid
Thanks for the real world review. We're about the same height and I'm wondering how you liked the overall fields of vision when cornering left and parking. Is there much of a dead zone created by the base of the front post and mirror?
