Maverick is using 8F35 transmission. But why not the heavy duty transmission (8F57)?
jmcgon237
Jerry
Landrum, SC
Ford Maverick Nissan Frontier
In the 8F series transmission they make 3 torque rated versions. Maverick is using the middle rated 8F35 but there is an 8F version that can handle more torque, the 8F57. Does anyone know why Ford does not use it on the Maverick especially on the 4K towing units. I would assume the case and weight are the same and only internal items are stronger. And I do not know if the 8F57 was ever used with 4WD.
  • Like
Reactions: JJC
Big_T
T
2022 Maverick XL Hybrid
I don't know anything about it, but are you sure it's "heavier"? Maybe it's just for a different application for some other specific reason? Do you know what vehicle the 8F57 is used in? I do believe the 4K towing gets a lower (higher numerically) final drive.
mamboman777
Josh
NRH, TX
In the 8F series transmission they make 3 versions. Maverick is using the middle version 8F35 but there is a heavier version the 8F57. Does anyone know why Ford does not use it on the Maverick especially on the 4K towing units.
I'd wager that the transmission is different in the 4k vs non-4k trucks.
Txjay
Keith
corpus christi texas
Jeep XJ
You think Ford would mention this as an upgrade so more people would go for it?
I doubt there is a difference.
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
It appears the 8F57 transmission is only for high torque V6 engines, such as the 2.7L V6 EcoBoost. That engine pushes out a little less than 100hp more than the 2.0L Ecoboost found in the Maverick, as well as about 100lb more torque.
It is likely overkill for the Maverick, an unnecessary waste of weight and cost.
MavrickEcoBoost
Tennessee
2019 Ranger
The 8F35 is a good transmission. The 4K towing adds in the oil cooler and bigger radiator. When towing it isnt so much about what transmission is in there. It is how to keep it cool. The stand alone cooler on the 4K package makes it just as good if not better than the 8F57.
dedMann
The Zone
FX4/LUX,60 Bug,ElementSC 5mt,Buell XB12X,BICYCLES!
I'm curious if we can the extra transmission cooling found on the tow package to our trucks? I think traffic jams in Phoenix would warrant the extra cooling. This is my first Automatic transmission on 4cyl w/turbo. I know this little guy is going to make some heat and fatigue.
MavrickEcoBoost
Tennessee
2019 Ranger
You would need everything attached to make it work.
dedMann
The Zone
Mega Thanks! I hope this can be done easily and the engineers didn't ruin this ability to do this..
MavrickEcoBoost
Tennessee
2019 Ranger
It looks pretty complicated. It isnt showing where the plugs are on the transmission. But by the look of the tubes it would be near the fire wall.
Potatomafia
Eastern New Mexico
2023 Ford Maverick XLT Hybrid
I'm glad someone asked this question as I had the same concerns. Just looking at the numbers, the 2.0L in the Maverick exceeds the torque rating of the 8F35. There could have been incremental improvements to increase the torque rating since the specs were published or Ford is planning on internal improvements for the Maverick especially for the Max tow package.
Looking at pics of the 8F35, it looks very similar to the 6F35 that was in my 2015 Transit Connect. Sadly, that trans committed seppuku. It suffered from axle seal leaks (documented in the Fusion) and the previous owner let the trans fluid level drop but continued to drive it. I got it and tried to rehab it but it blew up.
Big_T
T
Numerically higher
Correct, of course. Not sure why I wrote that. Like one of the test questions in school you know the answer to, and you write the wrong answer LoL.
To give some value to this post, the 2022 Ford towing guide lists the following axle ratios:
2.91 : 1 Hybrid (2k towing)
3.63 : 1 Ecoboost (2k towing)
3.81 : 1 Ecoboost (4k towing)
