Right on. They are nice, you will like them.This sold me on the Toyo tires. Look like a good deal and with some rugged rims looks decent. Thanks for posting.
Just wanting to confirm- the HRG description says it maintains factory rake, but you report it measuring a level 35" on front and back?I installed the lift kit with my buddy and then after we finished, I took it in to get an alignment. They adjusted the toe I think and said the rest really wasn’t off at all. It’s 35” from the ground to where the fender starts. It’s 35” on the front and the rear. It’s spot on level. No I’ll effects, it rides nice and the kit is high quality.
Not sure why they say that, maybe message them but mine is level with no rake anymore. That was the look I was after. So you should be golden if you are after the same thing.Just wanting to confirm- the HRG description says it maintains factory rake, but you report it measuring a level 35" on front and back?
I would prefer a kit that levels, so your experience may sell me on HRG.
That was a custom box that I got made.Where did you find that JL box to fit in the rear seat?? I purchased a 8” JL amp powered ported box. That didn’t fit under the rear seat bench. It’s currently behind my drivers side floor board
No.Are you running any spacers behind the wheels?
I’m 6’4”, this truck has excellent head room. I’ll measure it when I get home. But you should definitely do the lift and the wheels regardless.Hey OP - Looks great! Trying to decide If I should do the lift + tires since I'm a giant at 6'6"... Do you have a new total height to the top of the cab now that it's complete? I think stock height was 68.7" to the top of the cab.
Is it an issue that the bore size of the rims are .1mm larger than the spec of 63.4
