https://www.autotrader.com/car-news/highest-mileage-new-york-city-taxis-arent-what-you-think-255766You do know CVT trannies are not the most durable kind right?
I can't really "tell you different," because I can't figure out what you are saying.Yes the manufacturer wants you to not only make it thru the warranty, but for many years beyond.
I've worked on product development teams, heard this come out of managers mouths, but go ahead tell me different.
Yup.Maybe its antidotal, but 50K tranny flush for me. 200K for engine coolant, another no go. Coolant becomes acidic over time, but by all means follow that schedule if you put 200K in 3yrs time
I'd expect the opposite is likely.... I wouldn't be surprised to learn that the (transmission fluid is) able to last longer ...
Because the random guy on the internet has the car, has driven far enough for an oil change, and is telling you what Ford's system actually does. It's called a "first-person report."... But why would I believe the manual when some random guy on the internet says different?
Don’t think of th eCVT like a typical transmission. There are no clutches to slip and cause heat, no torque converter. The eCVT is more like a differential.I'd expect the opposite is likely.
A motor home taught me that automatic transmission fluid hates heat. The tranny fluid in an eCVT is not just lubricating, it's cooling the stators of the electric motors. No idea what vehicle usage pattern might heat-stress the stators, but it's one reason I'll stick to mfr. recommendation.
In my experience, Ford's manual's need a lot of work. No one's done a functional review, much less copy editing, in many years. Many things are missing or inaccurate, so I tend to believe my car over the manual. Your call.
For example, at the moment, FordPass says I have "54% oil life remaining" but it thinks I need an oil change in 1,300 miles. It's been 8,700 miles since the last change, but that includes 4,000 EV miles. Sounds like the 54% is right (~9,000 miles to go), and the 1,300 miles is wrong.
That's not obvious without knowledge of how the system works. Some readers may find that useful information.
Do you know this is a eCVT with planetary gears, not a CVT with belts.You do know CVT trannies are not the most durable kind right?
You know I responded to a post presenting some correct quotes from the manual, right?Because the random guy on the internet has the car, has driven far enough for an oil change, and is telling you what Ford's system actually does. It's called a "first-person report."
..You do know CVT trannies are not the most durable kind right?
I have a beef with inaccurate documentation. It's hard to press a button that's not there.... you do seem to have a beef with FordPass ...
I test on removal. Here's what Blackstone saw. (* indicates oil additives) At this mileage, all the wear metals look better than the C-Max, which I tracked to 66K miles. No worries here.Testing oil at intervals will be the only way to prove or disprove the accuracy of what the engineers programmed the olm for.
FordPass? I recommended reading the actual manual instead of listening to unknown people on the internet. I stand by that. I didn't recommend FordPass. (See Google for complaints about FordPass's handling of oil life.)I have a beef with inaccurate documentation. It's hard to press a button that's not there.
In the case of the oil monitor, FordPass is both accurate (54%) and inaccurate (1,300 miles).
I have two versions for my 2020, dated 7/2019 and 12/2019, about right for a 1/2020 delivery.I recommended reading the actual manual i
Yes, but it's a differential that shares tranny fluid with a pair of stators rated for ~400 Amps. Each. High power electrical systems are all constrained by their thermal limits. The potential is there to cook the fluid. A good control system design won't allow that....There are no clutches to slip and cause heat, no torque converter. The eCVT is more like a differential.
Since we are reviewing history... I actually responded to Post #6 -- not to Post #1, and not to you. I made the general comment that reading the manual was better than taking contrary advice from a random person on the internet. You assumed I was talking about you, but I wasn’t. Why? Because you gave essentially the same advice as the manual -- “Follow the Oil-Life Monitor.”I'm just saying "believe the oil life monitor" because Post #1 didn't.
That's fair; I own that. My apologies.You assumed I was talking about you, but I wasn’t.
